Should the BluePill and MapleMini init code call Serial.begin
Post by RogerClark » Thu Nov 24, 2016 7:09 am
I noticed that unlike LibMaple, if I don't call Serial.begin( in setup() I don't get Serial USB.
This is not a problem until you want to upload, because the IDE has no way to rest the board back into the bootloader unless Serial USB is running.
Perhaps at least for the Maple mini, we should replicate what LibMaple does, otherwise I can foresee a load of questions about why people can't upload.
e.g.
For the Uno etc, you do not need to call Serial.begin to be able to upload.
So perhaps if the user selects the Bootloader upload option, the code should call Serial.begin for the user.
Re: Should the BluePill and MapleMini init code call Serial.begin
Post by stevestrong » Thu Nov 24, 2016 8:13 am
RogerClark wrote:if the user selects the Bootloader upload option, the code should call Serial.begin for the user.
+1
zoomx
Post by zoomx » Fri Nov 25, 2016 1:50 pm
The UNO has the serial/USB converter that is active, so you have serial port in PC even if there is not any MCU on the board. It is an adapter built with an MCU or a chip as in clones.
Leonardo is different, since USB is built in. I don't have any Leonardo but I guess that it is the bootloader that ask the PC for a serial port maybe Leonardo uses serial load instead of DFU mode.
Post by RogerClark » Fri Nov 25, 2016 7:32 pm
I think I have a pro-micro board, which is like the Leonardo, so I will see what it does.
I think it can be USB HID as well as USB Serial, but I dont know how that works
