USB HID and composite
The official STMicroelectronics Arduino core
gungsukma
Re: USB HID and composite
Post by gungsukma » Thu Jan 12, 2017 7:29 am
I want to use keyboard and mouse from my Blue Pill (STM32F103C8T6).
Searching "HID" in this forum and ends up here.
Well, will be very nice to have Keyboard/Mouse, and on the same time, serial. :D
So I install STM32Duino, here what I was done, if I remember correctly:
1. Extract Arduino-1.8.0 IDE
2. Make Arduino-1.8.0\Portable folder (I use external hard drive)
3. Install Arduino Zero board
4. Extract Arduino-1.8.0\hardware\Arduino_STM32-master (Arduino_STM32-master.zip)
5. Run Arduino-1.8.0\hardware\Arduino_STM32-master\drivers\win\install_drivers.bat
7. Test "blink", success.
And for the HID:
1. Make Arduino-1.8.0\hardware\STM32_official folder
2. Extract Arduino-1.8.0\hardware\STM32_official\STM32F1 (Arduino_Core_STM32F1-USB_HID_Composite.zip)
3. Remove Arduino-1.8.0\hardware\Arduino_STM32-master\STM32F1
4. Extract Arduino-1.8.0\hardware\STM32_official\Tools (Arduino_Tools-master.zip)
5. Remove Arduino-1.8.0\hardware\Arduino_STM32-master\Tools
6. Try to compile this code:
#include "USBDevice.h"
#include "Mouse.h"
#include "Keyboard.h"
#define BUTTON_PIN 32
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(BUTTON_PIN, INPUT);
  USBDevice.beginSerialHID(&Mouse, &Keyboard);
7. Got this error: :cry:
In file included from D:\arduino-1.8.0\Portable\sketchbook\serial-hid\serial-hid.ino:1:0:
D:\arduino-1.8.0\hardware\STM32_official\STM32F1\cores\arduino/USBDevice.h:8:24: error: 'USBD_HandleTypeDef' has not been declared
         void attachUSB(USBD_HandleTypeDef *usbDevice, uint8_t HIDReportID);
D:\arduino-1.8.0\hardware\STM32_official\STM32F1\cores\arduino/USBDevice.h:13:9: error: 'USBD_HandleTypeDef' does not name a type
         USBD_HandleTypeDef *usbDevice;
Multiple libraries were found for "Mouse.h"
 Used: D:\arduino-1.8.0\hardware\STM32_official\STM32F1\libraries\Mouse
 Not used: D:\arduino-1.8.0\libraries\Mouse
Multiple libraries were found for "Keyboard.h"
 Used: D:\arduino-1.8.0\hardware\STM32_official\STM32F1\libraries\Keyboard
 Not used: D:\arduino-1.8.0\libraries\Keyboard
exit status 1
Error compiling for board BluePill F103C8.
8. Removing folder Arduino_STM32-master, same
"'USBD_HandleTypeDef' has not been declared"
May be I miss some steps?
:idea:
Board: BluePill F103C8
Upload Method: Serial
OS: Windows 7 32 bit
Post by stevestrong » Thu Jan 12, 2017 8:08 am
Serial upload is only targeted to be used for bootloader.
Try the "Stm32duino bootloader" upload option, otherwise is not guarantied that the serial USB is compiled.
danieleff
Post by danieleff » Fri Jan 13, 2017 5:25 am
Can confirm that the error is because of the serial upload method.
If you really want to upload via Serial, you can workaround by adding `BluePill_F103C8.menu.upload_method.serialMethod.build.upload_flags=-DSERIAL_USB` to the `boards.txt`, although this will change `Serial` to USB , and `Serial1` will be the UART1.
I will have to modify the code so that USB is included if the chip has USB, and not only if Serial-is-USBSerial based on menu settings. Or something.
gungsukma
Post by gungsukma » Fri Jan 13, 2017 6:35 am
1. D:\Arduino-1.8.0\hardware\Arduino_STM32-master\tools\win\stm32flash.exe -w generic_boot20_pc13.bin -v -g 0x0 COM5
2. Boot0: LOW
3. Use the USB cable data.
4. Upload method: STM32duino bootloader
5. serial-hid.ino as below
#include "Mouse.h"
  pinMode(PC13, OUTPUT); // PC13 and LED_BUILTIN
void loop(){
  digitalWrite(PC13, HIGH);
  digitalWrite(PC13, LOW);
  Keyboard.write('a');
  Keyboard.write('b');
  Keyboard.write('c');
  Keyboard.write('d');
  Keyboard.write('e');
  Keyboard.write('f');
  Keyboard.write('g');
  delay(5000);
6. Upload OK :D
The line below is the result:
abcdefgabcdefgabcdefgabcdefg
Thank you very much.
mobi123
Post by mobi123 » Fri Feb 17, 2017 9:10 am
D: \ Arduino \ hardware \ Arduino_STM32-master \ STM32F1 \ cores \ maple \ USBDevice.cpp: 2: 22: fatal error: usbd_hid.h: No such file or directory
  #include "usbd_hid.h"
Compilation terminated
Exit status 1
Compiler error for development board Generic STM32F103C series.
gungsukma
Post by gungsukma » Tue Feb 21, 2017 9:55 am
Exit status 1
If you follow my steps above, there should be the file on this location:
D:\arduino-1.8.0\hardware\STM32_official\STM32F1\system\Middlewares\ST\STM32_USB_Device_Library\Class\HID\Inc\usbd_hid.h
Upload Method: STM32duino bootloader
weslleymata
Post by weslleymata » Mon May 29, 2017 7:18 pm
My is not working, I'm using windows 10, uploader: STLink IDE: Arduino 1.8.1
I want to use the Keyboard function.
Thank you.
C:\Users\weslley.mata\Documents\Arduino\libraries\Mouse\src/Mouse.h:25:17: fatal error: HID.h: No such file or directory
 #include "HID.h"
KHODIDAS11
Post by KHODIDAS11 » Mon Aug 21, 2017 11:12 am
Hi daniel
I want interface USB Keyborad to stm32f407 black, Please help.
I have done USB serial using SerialUSB.begin(): and works fine.
newhero
Post by newhero » Thu Jan 18, 2018 3:59 am
kungsukma,
I followed your post and got a success to usb keyboard.
I'm thinking to make a ir-usb cordless keyboard.
I tried to use timer in my code in addition to the codes you showed.
But, with the way library included, the code below is not working showing
  Timer2.setPrescaleFactor(1024);
stm32duino_usb_test:33: error: 'Timer2' was not declared in this scope
or
HardwareTimer timer(1);
==>'HardwareTimer' does not name a type
Both of them were working good with the board, "Generic STM32F103 Series", while USB is not working with the error USBDevice.h not found.
Could you use timer/counter in your arduino environment?
Thanks.
arpruss
Post by arpruss » Thu Jan 25, 2018 3:47 am
In case it helps, I don't have any trouble compiling the following with Roger's main core and my USBHID library (which by default is composite serial / HID, though the serial must be accessed with CompositeSerial instead of Serial):
#include <USBHID.h>
  USBHID.begin(HID_KEYBOARD_MOUSE);
