USB HID and composite
danieleff
Re: USB HID and composite
Post by danieleff » Sun Nov 27, 2016 6:37 am
On Win10, Arduino 1.6.10, Java 1.8.0_92-b14.
It seems I do not have to use libwdi, as Win10 takes care of the serial driver automatically, in the event manager:
Driver Management concluded the process to install driver usbser.inf_amd64_5de2576d6f02918e\usbser.inf for Device Instance ID USB\VID_0483&PID_5750&MI_00\6&2B048C5C&0&0000 with the following status: 0x0.
Driver Management has concluded the process to add Service usbser for Device Instance ID USB\VID_0483&PID_5750&MI_00\6&2B048C5C&0&0000 with the following status: 0.
The Win7 machine does not have Arduino as it is an old laptop, so I just checked if the device manager lists the COM port (After running wdi installer). If it still does not work for you, I may install the IDE on that.
Post by RogerClark » Sun Nov 27, 2016 6:39 am
Update.
Installing the latest IDE fixed it. I think I may have had a custom version of listports.dll installed, but I can't remember why I did that .
Anyway....
When I push the button I just get a message via Serial USB, but I don't seem to get a real button push on the mouse.
And if I push the button a few times it seems to crash after the 4th push
As all I get is
Button pressed
Button pressed
Button pressed
Button pressed
If I push a few more times nothing happens
Post by RogerClark » Sun Nov 27, 2016 6:49 am
Daniel
I tried
int c=0;
int previous_buttons = 0;
unsigned long m=0;
 if (millis() - m>1000)
  Serial.println(c++*2);
  m=millis();
  if (previous_buttons != digitalRead(BUTTON_PIN))
    hidreport[0] = digitalRead(BUTTON_PIN) ? 1 : 0;
    previous_buttons = hidreport[0];
    USBD_HID_SendReport(&hUsbDeviceFS, hidreport, 4);
    digitalWrite(LED_BUILTIN, hidreport[0]);
    Serial.println("Button pressed");
And serial keeps outputting until I press the button 3 times.
After that it stops.
But its not completely broken, becuase the IDE can reset the board to upload, so the USB Serial is still receiving data, just not sending it
The code has not totally crashed either as the LED still lights when I press the button
danieleff
Post by danieleff » Sun Nov 27, 2016 7:15 am
It seems it thinks the whole device is serial, and tries to parse the button HID reports too.
I would still try to install with --iid 0 so only the serial interface part gets the serial driver (and uninstall the previous from 0x5750, or use differen PID usbd_desc.c).
Post by RogerClark » Sun Nov 27, 2016 7:24 am
I tried using --iid 0 but I have not totally changed the PID (again)
I'll move it to --pid 0x5751 and let you know what happens
Post by RogerClark » Sun Nov 27, 2016 7:37 am
Tried 0x5751 and also 0x5760
HID is now working but Serial driver won't load
I tried running
"%~dp0wdi-simple" --vid 0x0483 --pid 0x5760 --iid 0 --type 3 --name "Maple Serial" --dest "%~dp0maple-serial"
But it didnt install the driver
If I remove the --iid 0 the Serial driver appears but HID is removed :-(
danieleff
Post by danieleff » Sun Nov 27, 2016 7:43 am
Thank you for your trouble. I will investigate further from my Win7 laptop next week. Seems like the only missing thing is to install the serial driver to only that part of the device (which should be --iid 0), not the whole. (I mean it works on my Win10 both simultaneously )
*EDIT sorry for the additional installed drivers. Do you know how to remove them from a PID (when the device is not plugged in)? :)
Post by RogerClark » Sun Nov 27, 2016 8:58 am
No worries
I'll recompile for 0x5760, and 51 and 50 and see if I can remove them manually after loading each version into the Maple mini
BTW.
I tried using this http://www.nirsoft.net/utils/usb_devices_view.html it didnt seem to remove the drivers, even though it claimed it could
Post by RogerClark » Sun Nov 27, 2016 9:03 am
Daniel
BTW. It would be better if you updated your makefile from the one in the WIP branch as you makefile has a problem with the VL Discovery build unless I do "make clean" first.
I'm sure this has been fixed
Post by RogerClark » Sun Nov 27, 2016 9:37 am
Daniel
I tied connecting to a different machine, albeit one that had a Maple Mini connected before (but not the new STM repo and STM Virtual serial port etc.
And I got this USB installation popup (Sorry for the low quality, I had screengrab on one machine and email it to another and it didnt come out of the email in high quality.
This looks strange.
I'm not sure why it has the Maple 003, and 2 x STM32 Virtual ComPort, as well as the USB Composite device
Are you sure you built the USB descriptor tables correctly ?
