USB HID and composite
danieleff
Re: USB HID and composite
Post by danieleff » Tue Dec 13, 2016 4:52 pm
Freakeyyy wrote:
danieleff wrote: Or copy the joystick library, and modify it. Its copy-paste duplicate.
Do you mean copy the Mouse library and modify it ?
I meant copy https://github.com/MHeironimus/ArduinoJoystickLibrary . Which I just did.
For example this works now, looks like a gamecontroller on my win10:
#include "USBDevice.h"
#include "Joystick.h"
#define BUTTON_PIN 32
Joystick_ Joystick;
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(BUTTON_PIN, INPUT);
  USBDevice.beginSerialHID(&Joystick);
  Joystick.begin();
int previous_buttons = 0;
int y;
  if (previous_buttons != digitalRead(BUTTON_PIN)) {
    previous_buttons = digitalRead(BUTTON_PIN) ? 1 : 0;
    Joystick.setButton(0, digitalRead(BUTTON_PIN));
    Joystick.setYAxis(y);
    y += 10;
    digitalWrite(LED_BUILTIN, previous_buttons);
If I can somehow make the original library work, this copy needs to be removed.
Now I'll try to remove the need to call `USBDevice.beginSerialHID(...);`. To be coordinated with viewtopic.php?f=48&t=1581
Elektrik
Post by Elektrik » Tue Dec 13, 2016 11:14 pm
Good day, tested Joystick on windows 10 x64, seems to work well, buttons are read fine, now continue to test if pot value is passed as axis correctly. One issue I found - if I upload sketch when stm32 is already connected - it works fine. Once I reset/unplug-plug, it does not load as HID device. The actual sketch is flashed, just some issues during enumeration, will try to add delays before USBDevice.beginHID.
Update:
Did not manage to check axis, since cannot read adc value (INPUT_ANALOG is not declared to turn on adc pin), tried to set bits manually, but it's too different in comparison with maple core definitions on original arduino_stm32 repo.
danieleff
Post by danieleff » Wed Dec 14, 2016 5:55 am
Elektrik wrote: Did not manage to check axis, since cannot read adc value (INPUT_ANALOG is not declared to turn on adc pin), tried to set bits manually, but it's too different in comparison with maple core definitions on original arduino_stm32 repo.
INPUT_ANALOG is just a maple implementation thingy, and is not needed in the original arduino code or in this core. See the official example, no need for pinMode().
However there is an issue with the pin numbers that can be used as analog pins: https://github.com/stm32duino/Arduino_C ... /issues/28 (Basically do not use pins < 16)
Are you using bluepill or maple mini?
Elektrik
Post by Elektrik » Wed Dec 14, 2016 4:55 pm
Oh, thank you for reply, that's might be an issue, since I tried it on A0 pin, will try now to use different pins.
danieleff wrote: Are you using bluepill or maple mini?
I do use generic stm32 board
danieleff
Post by danieleff » Wed Dec 14, 2016 5:06 pm
That is the bluepill, PB0 should work for now. And nothing else... for now. @RogerClark I would like to send PRs for these, just do not know which branch.
Elektrik
Post by Elektrik » Wed Dec 14, 2016 6:12 pm
Tried on PB0, this cause board sometimes returning "Unkwnown USB descriptor", or sometimes it runs until analogRead() and then crashes.
#define LED_BUILTIN PC13
Joystick_ Joystick(0x01,  0x04,   10,  0,  true,  false,  false,  false,  false,  false,  false,  false,  false,  false,  false);
int val = 0;
  Joystick.begin();
    Joystick.setButton(1, previous_buttons);
    digitalWrite(LED_BUILTIN, !previous_buttons);
    val = analogRead(PB0);
    Serial.println(val);
    Joystick.setXAxis(val);
Post by RogerClark » Wed Dec 14, 2016 7:33 pm
Daniel
I think Frederic @ STM is happy to have the new code in the master branch.
I think one of Frederic's PRs effectively moves the changes in the WIP branch into master, but I have not had time to test the PR, so those changes have not been made to the master yet.
Sorry. I have been very busy with commerical work, as I have pre-christmas deadlines and also deadlines due to Chinese New Year, ( my contacts in China start their holiday on 12th Jan, for about 3 weeks).
So I have not had time to test and pull the PRs from Frederic.
As I do not derive any income from STM etc, my work has to come first.
X71
Post by X71 » Fri Dec 30, 2016 2:55 am
This is what I've been trying to do on my F103VET6 board for a while now, but I'm confused on the actual architecture.
I've managed to get my board to boot as a USB Serial Device (thanks to Roger's FAQ), but I don't fully understand how to "turn" it in to a USB HID.
Is the code presented in this thread supposed to be the "bootloader" of the board, or do you just upload the code as a "sketch" and when plugged into the PC it's operates as a USB HID?
Can some provide a step by step guide on how I could get this running on my board?
danieleff
Post by danieleff » Fri Dec 30, 2016 3:19 pm
X71 wrote:This is what I've been trying to do on my F103VET6 board for a while now, but I'm confused on the actual architecture.
If you run on F103VET6, thats probably the libmaple core.
This one is for the official core (that does not have support for F103VET6 currently), install as here: viewtopic.php?f=16&t=1553 , except use my branch: https://github.com/danieleff/Arduino_Co ... _Composite
X71
Post by X71 » Sat Dec 31, 2016 12:46 am
It works !!!
You don't know how long I've been trying to get this to work ... thanks for your help @danieleff and especially @RogerClark for helping out a newbie :)
