[Solved] Which define defines the stm32 core for libraries?
The official STMicroelectronics Arduino core
tomvdb
Post by tomvdb » Fri Jul 21, 2017 10:57 am
So I'm trying the various libraries I usually use for arduino projects and testing/fixing to work with my stm32 board. The question is what define can I use in the library to determine if its using the stm32 core?
For example:
#if defined(__AVR__)
 #define WIRE Wire
#elif defined(CORE_TEENSY) // Teensy boards
 #define WIRE Wire
#else // Arduino Due
 #define WIRE Wire1
Is there something like STM32_CORE define that I can use for adding my changes?
martinayotte
Re: Which define defines the stm32 core for libraries?
Post by martinayotte » Fri Jul 21, 2017 1:33 pm
There are severals ones, but the most common is __STM32F1__ or __STM32F4__, depending of MCU type.
Simply look at the compile command with verbosity turned-on ...
Wi6Labs
Post by Wi6Labs » Fri Jul 21, 2017 3:14 pm
You can simply use the define STM32 (Here)
Wi6Labs team
tomvdb
Post by tomvdb » Sat Jul 22, 2017 10:02 am
perfect thanks :)
Post by fpiSTM » Mon Jul 31, 2017 9:11 am
the good one is ARDUINO_ARCH_STM32
STM32 is not defined.
