where to use DFU Upload method
junhua
Post by junhua » Wed Jan 03, 2018 8:50 am
Hello all
https://github.com/stm32duino/wiki/wiki ... oad-method
I need to use the DFU Upload method, but I can not find it in ardunio Upload method ??
junhua
Re: where to use DFU Upload method
Post by fpiSTM » Wed Jan 03, 2018 10:03 am
It is currently not available for the current supported board.
As mentioned in the Wiki:
Depending of the board, several upload method could be proposed
When it will be supported it will be displayed in the upload menu.
Post by stevestrong » Wed Jan 03, 2018 12:59 pm
Unless you would like to use the Arduino_STM32 core being the main (original) focus of this forum.
junhua
Post by junhua » Thu Jan 04, 2018 6:06 am
Yes, I have check it before.
But seems all for F103, Here I use F303RE. I think it need much work to support it , is it possible ?
junhua
Post by junhua » Thu Jan 04, 2018 9:09 am
Hello
By the way How to use the Mass Storge, it is possibe for STM32F303RE ?
Post by mrburnette » Thu Jan 04, 2018 4:07 pm
There is "Arduino-ish" support for the Official ST Nucleo boards here:
So, if you are using an Official Nucleo board, please use the correct core files. That is, do not use Roger Clark's core (derived from Leaflabs.)
User fpiSTM generally answers Official Board questions but others may chime in, too.
Post by fpiSTM » Thu Jan 04, 2018 7:26 pm
Yes it's possible as the F303RE is available with the STM core.
Select "Mass Storage" in "upload method" menu and that's all.
It's only a copy of the .bin file.
You have to connect the board thanks the integrated STLink in order to have the mass storage volume mounted.
junhua
Post by junhua » Fri Jan 05, 2018 3:27 am
hello
We do not use the on board STLINK , we hope use F303RE USB direct to upload firmware with DFU mode .
junhua
Post by mrburnette » Fri Jan 05, 2018 1:50 pm
hello
junhua
From the Google search form:
DFU site:wiki.stm32duino.com
That will give you all of the hits on DFU in the WiKi. For the github WiKi:
DFU site:https://github.com/rogerclarkmelbourne/Arduino_STM32/wiki
And finally, for the original documentation from Leaflabs:
DFU site:leaflabs.com
That essentially is the non-forum repository for DFU dialog/knowledge.
As you are using the Nucleo outside of the manner in which fpiSTM has suggested, I suspect you are on your own to find/resolve a solution to this issue. fpiSTM is the authority on answering questions related to Arduino core on Official STM Nucleo boards.
The Nucleo boards core is located within this link: https://github.com/stm32duino
The stm32duino.com forum does not support the F303RE with our core.
Post by RogerClark » Fri Jan 05, 2018 8:15 pm
You could look at Koduino ( written by Avik De), it supports F3 processors, however it does not seem to have much community support.
( google it )
