[Fixed] analogRead results for BluePill and MapleMini
Posted: Sat Dec 17, 2016 8:13 am
by danieleff
This code:
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.println(analogRead(PIN));
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
Gives the following results for different PIN values:
Board: MapleMini
Program crashes: 0, 1, 2, 3, 9, 16, 17, 18, 19, 25
"0" on serial: the rest of the pins
Expected: analog value on serial for pins 3..11; "0" for the rest of the pins
Board: BluePill
Program crashes: PA3, PA4, PA5, PA6, PA10, PB3, PB4, PB5, PB6, PB10
Incorrect analog value on serial: PA0 reads the PB0 pin
Correct analog value on serial: PB0
"0" on serial: rest of the pins
Expected: analog value on serial for pins PA0..PA7,PB0; "0" for the rest of the pins
The reason for these is multiple:
  • wrong pins are considered to read: https://github.com/stm32duino/Arduino_C ... /issues/28
  • crashes: analogread and PWM pins are in the same g_analog_config array, and trying to analogread from a PWM pin will get you a adcInstance=NULL -> crash
  • array out of bounds for g_anInputPinConfigured. its size is 7, but in analogRead the apin variable has values of 0..15
  • * EDIT: The following ADC pins are missing from g_analog_config: PA2, PA3, PA6, PA7(!), PB1
Re: analogRead results for BluePill and MapleMini
Posted: Mon Dec 19, 2016 1:04 am
by mrburnette
Then, as in the example program, set the chosen pin’s pin mode to INPUT_ANALOG by calling pinMode(<your_pin>, INPUT_ANALOG). You will usually do this in your setup() function. Now you can use analogRead() to perform an ADC reading.
Examples are available for most basic capabilities; always try an example first.
Posted: Mon Dec 19, 2016 2:06 am
by Rick Kimball
mrburnette wrote: Examples are available for most basic capabilities; always try an example first.
I think this question is about the ST core not the maple core.
I took the first stab at getting the bluepill to work with the ST core. I quickly determined that Wi6labs didn't care about non nucleo boards. This observation based on the code and their forum responses. I've stopped looking at the ST official port. Unless some one has fixed up the pin map code, I think this post is still valid.
viewtopic.php?f=48&t=1407&start=10#p18075
When I did the first port I didn't see a quick way to add more pins without breaking the analog feature, so I broke it, mainly to get a feel for the code.
btw: all the posts in that thread are a good read to understanding the issues with using the ST core with our boards.
-rick
Posted: Mon Dec 19, 2016 2:46 am
by RogerClark
I mentioned to Frederic @ STM, that I though that the STM Core was written only for the Nucleo, and he has said that it was not STM's intention.
However, (in my reply to Frederic), I referenced the various things including things like hard coding of pins deep in the code (for I2C), large RAM usage etc.
So I presume that this has been a misunderstanding between STM and Wi6Labs about what STM wanted them to create.
Either way this doesn't help us, make the STM core work on anything other than Nucleo boards.
Posted: Mon Dec 19, 2016 3:30 am
by mrburnette
-rick
Yes, Rick, I missed the "STM core:" in the forum link. I wish the alternate cores were in a separate forum instead of just a separate header section ... But, my bad.
Posted: Mon Dec 19, 2016 7:22 am
by RogerClark
mrburnette wrote: Yes, Rick, I missed the "STM core:" in the forum link. I wish the alternate cores were in a separate forum instead of just a separate header section ... But, my bad.
I've separated as much as I can, i.e this is in a separate section.
Posted: Mon Dec 19, 2016 3:57 pm
by mrburnette
Yes, Roger ... But it is not old-fart separated; that is, I have to put on my glasses to read the small type in the upper-left:
Board indexBootloaders and CoresSTM core: Bugs and enhancements
On the other hand, the subject line is in BIG font and can be read without glasses and I can respond without glasses:
It's not your fault I'm half blind; my personal problem. It's just that the forum sections are not well displayed; thus, when one pulls down from the Quick links menu "Active topics" it is very easy to get lost when the reader is 95% of the way to lost anyway.
