[Solved]Something odd about pin mapping
Please post bugs and enhancements for the STM core here
madman2003
Post by madman2003 » Sat May 13, 2017 10:59 am
It seems i cannot use the lower digital pins of an L476 for PWM because it falsely assumes the analog pins should be used instead.
I found this in variant.h:
// Convert an analog pin number Axx to a PinName Pxy
#define analogToPinName(p) ((p < NUM_ANALOG_INPUTS) ? digitalToPinName(p+A0) : digitalToPinName(p))
This function is then used by analogWrite()
Re: Something odd about pin mapping
Post by RogerClark » Sat May 13, 2017 9:14 pm
Which core are you using?
STMs official core or @grumpyoldpizza's core
i think they both support that hardware
madman2003
Post by madman2003 » Sun May 14, 2017 9:40 am
I'm using the official core, the 12-05-2017 version.
Post by RogerClark » Sun May 14, 2017 11:22 am
madman2003 wrote:I'm using the official core, the 12-05-2017 version.
Your best bet is to raise an issue on the L4 repo in GitHub.com/stm32duino
GrumpyOldPizza
Post by GrumpyOldPizza » Sun May 14, 2017 12:50 pm
It's a bug in ST's core. Neither the STM32L476 nor the SAMD core have those issues (nor does Teensy).
- Thomas
Post by fpiSTM » Wed May 17, 2017 8:53 pm
"Issue" has been fixed.
