[Solved] Arduino Core for STM32 v2018.1.18 Problem
Please post bugs and enhancements for the STM core here
Re: Arduino Core for STM32 v2018.1.18 Problem
Post by fpiSTM » Mon Jan 22, 2018 4:26 pm
There is no link with JSON file.
The input JSON file is only to install the required packages in Arduino local user path.
This line of code is in the platform.txt:
recipe.hooks.prebuild.1.pattern.windows=cmd /c "if not exist {build.opt.sourcepath} mkdir {build.path}\sketch & type NUL > {build.opt.path}"
with
build.opt.sourcepath={build.source.path}/{build.opt.name}
in your case
{build.opt.sourcepath} == C:\Program Files (x86)\Arduino\examples\01.Basics\Blink/build_opt.h
So you're right, it does not like space :roll:
I have to fix that as this is the default installation folder used by Arduino.
Windows will make me crazy :mrgreen:
Could you test to edit platform.txt:
and replace this line:
by this one
recipe.hooks.prebuild.1.pattern.windows=cmd /c "if not exist "{build.opt.sourcepath}" mkdir {build.path}\sketch & type NUL > {build.opt.path}"
Sorry for this issue
djw
Post by djw » Mon Jan 22, 2018 5:20 pm
Windoze makes us all nuts,...
The error changes:
Arduino: 1.8.5 (Windows 7), Board: "Nucleo-64, Nucleo F446RE, Mass Storage, Generic Serial, None, Smallest (-Os default)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Dan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Dan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dan\Documents\Arduino\libraries -fqbn=STM32:stm32:Nucleo_64:pnum=NUCLEO_F446RE,upload_method=MassStorage,xserial=generic,usb=none,opt=osstd -ide-version=10805 -build-path C:\Users\Dan\AppData\Local\Temp\arduino_build_613137 -warnings=none -build-cache C:\Users\Dan\AppData\Local\Temp\arduino_cache_437889 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.STM32Tools.path=C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\tools\STM32Tools\2017.9.22 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\tools\arm-none-eabi-gcc\6-2017-q2-update -prefs=runtime.tools.CMSIS.path=C:\Users\Dan\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Dan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Dan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dan\Documents\Arduino\libraries -fqbn=STM32:stm32:Nucleo_64:pnum=NUCLEO_F446RE,upload_method=MassStorage,xserial=generic,usb=none,opt=osstd -ide-version=10805 -build-path C:\Users\Dan\AppData\Local\Temp\arduino_build_613137 -warnings=none -build-cache C:\Users\Dan\AppData\Local\Temp\arduino_cache_437889 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.STM32Tools.path=C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\tools\STM32Tools\2017.9.22 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\tools\arm-none-eabi-gcc\6-2017-q2-update -prefs=runtime.tools.CMSIS.path=C:\Users\Dan\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'Nucleo_64' from platform in folder: C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\hardware\stm32\2018.1.18
Using core 'arduino' from platform in folder: C:\Users\Dan\AppData\Local\Arduino15\packages\STM32\hardware\stm32\2018.1.18
cmd /c "if not exist "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink/build_opt.h" mkdir C:\Users\Dan\AppData\Local\Temp\arduino_build_613137\sketch & type NUL > C:\Users\Dan\AppData\Local\Temp\arduino_build_613137/sketch/build_opt.h"
The filename, directory name, or volume label syntax is incorrect.
exit status 1
Error compiling for board Nucleo-64.
Post by mrburnette » Mon Jan 22, 2018 6:22 pm
I was a MCSE for years and Win 7 to Win 8 then Win 8.1 totally pissed me off. I made the Linux jump when Microsoft trashed my nicely hacked Windows 8.1 with the infamous Win 10 download. The rollback never worked correctly and I figured if I was going to have to reinstall anyway that Linux would be my choice. That was 2 years ago and I have never looked back.
Post by Rick Kimball » Mon Jan 22, 2018 7:19 pm
I love it when the cult members see the light : )
Post by Pito » Mon Jan 22, 2018 8:09 pm
Market share desktops/notebooks: Win 88.9%, Linux 2.3%.. :)
Post by zmemw16 » Mon Jan 22, 2018 8:30 pm
you could be a hard sell :!:
:D
Post by fpiSTM » Mon Jan 22, 2018 9:37 pm
I've tested and reproduce the issue...
So, the good line, to deal properly with space in path variable, is/should be/must be/I pray:
recipe.hooks.prebuild.1.pattern.windows=cmd /c if not exist "{build.opt.sourcepath}" mkdir "{build.path}\sketch" & type NUL > "{build.opt.path}"
That's why I prefer use Linux also... but need to also support win too.... :roll: for the 88.9%
Post by mrburnette » Mon Jan 22, 2018 10:31 pm
If we only supported Linux, there would be lots more Linux users! :lol:
Post by mrburnette » Mon Jan 22, 2018 10:33 pm
Sounds like the ratio of non-rich vs the very rich.
But the ratio does not itself make the wealthy bad (people.)
Post by zmemw16 » Mon Jan 22, 2018 10:36 pm
smart maybe :?:
