[Solved] Arduino Core for STM32 v2018.1.18 Problem
Please post bugs and enhancements for the STM core here
djw
Re: Arduino Core for STM32 v2018.1.18 Problem
Post by djw » Mon Jan 22, 2018 11:27 pm
WooooooooHooooooo!
It works! YES
Nothing better than pounding Windoze into submission.
Thank you very much for your diligence, and for working to bring these
STM boards to the Arduino IDE.
Dan
Post by RogerClark » Tue Jan 23, 2018 12:37 am
WooooooooHooooooo!
It works! YES
Dan
Hi Dan
I'll set the title to [Solved ....... ] but can you tell us how you fixed it.
Re: [Solved] Arduino Core for STM32 v2018.1.18 Problem
Post by fpiSTM » Tue Jan 23, 2018 5:23 am
Sum up of the solution:
Add to the windows environment variable %PATH%:
C:\windows\system32;
Fix in platform.txt to avoid issue with path including space:
recipe.hooks.prebuild.1.pattern.windows=cmd /c if not exist "{build.opt.sourcepath}" mkdir "{build.path}\sketch" & type NUL > "{build.opt.path}"
See https://github.com/stm32duino/Arduino_C ... 2/pull/204
Post by RogerClark » Tue Jan 23, 2018 5:28 am
Ah OK.
Its the new build options / recipe hook changes that were the problem
Post by fpiSTM » Tue Jan 23, 2018 5:35 am
Ah OK.
yes :roll:
Now it should be ok. I will add to my test list test as standard user (non admin) with the Arduino default installation path.
