Page 1 of 3
recipe.preproc.macros pattern is missing error
Posted: Sat Nov 05, 2022 2:54 pm
by OldManNoob
I am getting the following error when attempting to compile for the STMicroelectronics-stm32 library on A.IDE 1.8.19:
Error compiling for board Generic STM32F1 series.
:cry:
This error shows up without any other information when compilation is attempted.
I was using this library as the code I wrote needs printf for HardwareSerial support; it alone worked well at last use (sometime very early in the year) on the IDE1.8.xx.
I have not attempted to revert to an earlier version of the IDE, although I have completely uninstalled and re-installed, and tried various libraries(below).
:!: I also get an error on the much preferred IDE2.0.1, with the following showing without fail:
Request getBoardDetails failed with message: 14 UNAVAILABLE: No connection established when trying to compile - at which point I do not expect to have to be connected!
If anyone can point me at a library that will provide the needed printf support for the STM32F103C8T6 (Blue Pill) I would be really grateful.
Fi
Libraries I have tried (as well as the "(Arduino STM32)(included in sketchbook)" option which will not support printf for HardwareSerial) :
https://raw.githubusercontent.com/stm32 ... index.json,
Re: recipe.preproc.macros macros is missing error
Posted: Sat Nov 05, 2022 3:43 pm
Seems strange as it works fine for all ide. Could you share the full log.
Posted: Sat Nov 05, 2022 5:12 pm
by OldManNoob
Hi fpiSTM,
Using the library that I'd had success with (afaik - I am a noob really):
https://raw.githubusercontent.com/stm32 ... index.json It has been since altered; quite extensively inasmuch as I can make out.
If by "share the full log" you mean the entire output of the error messages window, with Compiler Warnings set to ALL :
  • recipe.preproc.macros pattern is missing
That's it.
Posted: Sat Nov 05, 2022 5:28 pm
Which core version you installed?
Posted: Sat Nov 05, 2022 5:35 pm
by OldManNoob
If the link https://raw.githubusercontent.com/stm32 ... index.json
does not complete that core install, then I may be missing a step. . ?
That links to ver 2.0.0
Posted: Sat Nov 05, 2022 5:59 pm
Latest is 2.3.0.
Your errors seems linked to a wrong install.
Posted: Sat Nov 05, 2022 6:01 pm
Or maybe you have an old one installed which could explain this issue...
Ensure to properly delete all old install.
Posted: Sun Nov 06, 2022 6:31 pm
by OldManNoob
My bad.
I have indeed 2.3.0 installed:
I have uninstalled all STM libraries, and all mention of STM in any file I can find. I have uninstalled 1.8.19, rebooted (W10 pro (X64) 22H2 ) and re-installed 1.8.19.
I am still getting the identical error recipe.preproc.macros error message with no other info. and I'm stuck for ideas.
I still cannot get the IDE 2.0.1 to even commence compilation as it looks for a board to get info from
IDE 2.0.1 now also shows the recipe.preproc.macros error message within a couple of seconds of attempting compilation - it also lists the 2.3.0 STMicroprocessors library as the only STM library installed
Re: recipe.preproc.macros pattern is missing error
Posted: Sun Nov 06, 2022 7:18 pm
Seems like install not complete or aborted.
And you have only this message? Try to launch arduino from a console to see if you have more info.
Posted: Sun Nov 06, 2022 7:40 pm
by OldManNoob
fpiSTM wrote: Sun Nov 06, 2022 7:18 pm Seems like install not complete or aborted.
I have no idea how to do this, so instead I'm uninstalling IDE 2.0.1 and re-installing to see what happens. I have been using 2.0.1 since release and no issues using Teensyduino libraries; it is only with the STM library I'm experiencing issues.
Re-install of 2.0.1: OK
Compile code for Teensy? OK
Compile code for STM32F103C8T6? Nope. Same error
