BennehBoy's Postbag
BennehBoy
Re: BennehBoy's Postbag
Post by BennehBoy » Tue Feb 07, 2017 1:49 pm
Some bits arrived with the postie...
Replacement ST-Link clone - this one works, although it's reporting my maple mini as having only 64kb flash? (given that my code size is currrently 66kb I'm not sure I believe it).
Replacement digitizer/glass for my daughter's iPad.
https://github.com/BennehBoy
BennehBoy
Post by BennehBoy » Fri Feb 10, 2017 6:56 pm
10 quid 8 channel logic analyser turned up in the post. Way easier to debug what's going on with my BT uart than echoing data to a serial line and wtahcing it come in on a terminal.
8 channel smd/micro probe clips
some prototyping board.
racemaniac
Post by racemaniac » Fri Feb 10, 2017 7:05 pm
what's the sample rate on that logic analyzer?
i started out with an 8 channel saleae clone that did 24MSPS, now i upgraded it to a 16 channel clone that does 100MSPS. once beyond 100MSPS they really start to get expensive ^^'
Post by RogerClark » Fri Feb 10, 2017 7:39 pm
I did the same.
But my 100MSPS analysers only operates at that speed if you only want to look 1 or 2 inputs.
If you want to look at 4 inputs e.g. for SPI the speed drops down to 50MSPS and 8 inputs is approx half that speed.
BennehBoy
Post by BennehBoy » Fri Feb 10, 2017 8:32 pm
BennehBoy
Post by BennehBoy » Fri Feb 10, 2017 8:34 pm
The software is a bit finicky to be honest - drivers have to be fudges into windows 10.
Post by RogerClark » Fri Feb 10, 2017 11:36 pm
BennehBoy wrote:The software is a bit finicky to be honest - drivers have to be fudges into windows 10.
Wont it run the Saelogic software ?
Actually if not you can just reflash it, I did the same thing with mine
Well, it was configured to work with the Saelogic sw but I reloaded it to another analyser (can't remember the name) but that software was useless, so i reflashed it back to being Saelogic compatible
Try
https://www.saleae.com/downloads
Basically these all have the same generic chips in them, and the only way the software distinguishes whether it runs on them is set by the USB VID / PID and you can change that quite easily
BennehBoy
Post by BennehBoy » Sat Feb 11, 2017 1:38 am
Cool
Post by RogerClark » Sat Feb 11, 2017 4:43 am
I found the article that discusses how to change the VID / PID on these
http://www.jwandrews.co.uk/2011/12/sale ... ogramming/
I vaguely recall you may need to run the Cypress software on Windows XP because of its drivers
Of course you stand a chance to bricking it, but honestly its worth it, and I managed to swap mine over and back again without any problems
BennehBoy
Post by BennehBoy » Sat Feb 11, 2017 11:37 am
Excellent, I'll have a pop at it later.
