BennehBoy's Postbag
Re: BennehBoy's Postbag
Post by zmemw16 » Sun Feb 12, 2017 2:26 am
you might look at the probes 'jaws', are they 2 strips with a kink in each or a single strip wrapped into a j sort ?
i usually take a pair of fine nosed pliers to the first and increase the kink somewhat.
BennehBoy
Post by BennehBoy » Sun Feb 12, 2017 11:19 am
2x kinked, they work quite well
https://github.com/BennehBoy
BennehBoy
Post by BennehBoy » Sun Feb 12, 2017 3:16 pm
Ha, can't believe how simple it was to switch that logic analyser over to being a 'Saleae Logic' one!
Cheers Roger!
Post by RogerClark » Sun Feb 12, 2017 10:00 pm
No worries.
BennehBoy
Post by BennehBoy » Sun Feb 26, 2017 3:27 pm
Bag of 10 3.3v micro SD readers arrived...
Here you can see one wired into a test board for the project I'm porting. Sdfat initialisation works fine.
BennehBoy
Post by BennehBoy » Wed Mar 01, 2017 10:05 pm
You can never have enough breadboard wires....
Also some more ADXL345's arrived - tbh probably bought in error but they were dirt cheap.
20x4 LCD & i2C driver - hooked this up to the project that I'm porting so I could run it using IDE 1.06 to check that the menu's function, they do which is dissapointing, this means that there's either an intrinsic difference that I don't understand between AVR and STM32 or something changed in the way that the IDE/compilation happens.
I'm not massively bothered because I'm going to ditch all the menu code for something better -> https://github.com/neu-rah/ArduinoMenu
BennehBoy
Post by BennehBoy » Fri Mar 03, 2017 7:48 pm
You can never have too many buttons...
Bag of 100 for a couple quid
Post by RogerClark » Fri Mar 03, 2017 8:48 pm
LOL
BennehBoy
Post by BennehBoy » Fri Mar 10, 2017 6:03 pm
74HC154's arrived in the post...
Found this little mux library on github -> https://github.com/MajenkoLibraries/MUX ... MUX154.cpp
martinayotte
Post by martinayotte » Fri Mar 10, 2017 8:00 pm
They should have named this library as DEMUX154 instead ... :ugeek:
