BennehBoy's Postbag
Re: BennehBoy's Postbag
Post by zmemw16 » Sat Mar 18, 2017 3:36 pm
the gasket blew or lengthened studs allowed pressure leak?
they're rather different failures.
and so, what's the next item/component in the failure tree?
BennehBoy
Post by BennehBoy » Sat Mar 18, 2017 11:07 pm
zmemw16 wrote:the gasket blew or lengthened studs allowed pressure leak?
Studs lengthened.
Next component failure will be well beyond the amount of power that could be made from the head without porting & increasing valve sizes.
https://github.com/BennehBoy
BennehBoy
Post by BennehBoy » Tue Jan 30, 2018 1:11 pm
These are the Blue PIlls that I ordered so that I can play around with debugging in VSCode (amongst other things).
https://www.ebay.co.uk/itm/STM32F103C8T ... 2246242164
Fingers crossed they've not got the dodgy USB resistors - although will be programming with SWD mainly.
Also snagged a couple of ESP32 boards to have a fiddle with - this slightly work related from an IoT perspective.
https://www.ebay.co.uk/itm/ESP32-ESP-32 ... 2091168511
Post by RogerClark » Tue Jan 30, 2018 8:14 pm
The RobotDyn boards ( black coloured boards) appear to be the best ones to buy at the moment.
They sell through their own site and also on Aliexpress.
Though I don’t think it’s worth paying 80 cents more for the version with the bootloader pre-installed, as all those 80 cents add up if you buy, 5 or 10 boards.
BennehBoy
Post by BennehBoy » Fri Feb 09, 2018 10:58 am
Blue Pill's arrived, R10 is incorrect value, but they seem to work fine. Was able to flash bootloader with STLINK and then upload blinky successfully.
Need to create a BluePill version of my project now to take care of pin allocations.
Will try debugging in vscode later.
michael_l
Post by michael_l » Fri Feb 09, 2018 3:57 pm
For some reason the attachment is not visible.
Does this VSCode Arduino plugin use Arduino framework for building, i.e. you can build project what is visible under "hardware" folder ?
BennehBoy
Post by BennehBoy » Fri Feb 09, 2018 5:44 pm
Yes.
I'll fix the image shortly - google images likes to do daft things.
Post by mrburnette » Fri Feb 09, 2018 6:19 pm
.... looks like someone is collecting 'nuff STM32 blue pills to start a stand-up pharmacy :lol:
BennehBoy
Post by BennehBoy » Fri Feb 09, 2018 6:35 pm
I've got about 40 uC's here lol.
Post by ahull » Sat Feb 10, 2018 12:06 am
I can't get over how cheap these bluepills have become.
Cheapest today is £1.49 At that price they really are "cheap as chips"... if not cheaper.
