Racemaniac's postbag
racemaniac
Re: Racemaniac's postbag
Post by racemaniac » Sat Jun 17, 2017 6:47 am
Another nice recent arrival is one of these: https://www.aliexpress.com/item/Free-sh ... 36178a3b09
When looking for logic analyzers that could go faster than 100MSample, i came across these affordable guys. Ordered one and gave it a try. So far looks pretty nice, beyond 100Mhz you have to rely on its buffered mode (and not buffered, 100Mhz is only 3 channels), but it can buffer 16 million samples per channel, has nice trigger options, and the software looks pretty decent :).
Haven't got much experience with it yet, but when doing my DMA tests i used it to check the clock lines of the SPI, and in 100Mhz mode i could already very clearly detect the 36Mhz spi clock of SPI1 @ full speed :). One of the things to get used to compared to a saleae is that you can configure the threshold voltage. For 3.3V operation i set it to 1.6V, and then you get very clean readings :).
Also an advantage seems to be that it supports more protocols. I see it knows SDIO while the Saleae software i have doesn't :).
To be tested further, but seems like a promosing device so far :). One tip if you want to buy one, i have the impression some sellers sell basically the same device but with only 16K samples memory depth... avoid those :p
Post by RogerClark » Sat Jun 17, 2017 7:18 am
Interesting.
What PC software do you use with it?
I have a 100Mhz Analsyer like this
http://www.ebay.com.au/itm/New-USB-Logi ... 1745053900
But it only supports 100Mhz on 2 channels.
I sometimes wish it also did analogue, but I have a scope so I cant justify buying another analyser
racemaniac
Post by racemaniac » Sat Jun 17, 2017 8:05 am
RogerClark wrote:Interesting.
The software can be found here: http://www.dreamsourcelab.com/dslogic.html
apparantly it originally was a kickstarter project, they're still working on their software, but the latest version seems very decent so far :). may become my main logic analyzer :)
Post by RogerClark » Sat Jun 17, 2017 11:03 am
Post by zmemw16 » Sat Jun 17, 2017 12:55 pm
does anyone else find after visiting an aliexpress russian page, your login page is now in russian?
what's russian for global?
srp
racemaniac
Post by racemaniac » Sat Jun 17, 2017 12:57 pm
zmemw16 wrote::( :( :( :(
srp
maybe visit it with google translate? XD
zoomx
Post by zoomx » Sat Jun 17, 2017 2:07 pm
I believe it changes some cookie where the language is set.
Post by stevestrong » Sat Jun 17, 2017 3:13 pm
There is always "Go to Global Site (English)" on the top right part of the page.
Or replace in the address field "ru.ali..." by "www.ali..."
Post by zmemw16 » Sat Jun 17, 2017 5:21 pm
that go to global is not visible on the normal login page.
just one of those many little things, that i shouldn't really have to do.
Post by RogerClark » Sat Jun 17, 2017 9:23 pm
Clear your cache and cookies etc, then manually go back to www.aliexpress.com
