Rogers postbag
Re: Rogers postbag
Post by RogerClark » Tue Nov 14, 2017 9:44 am
@Pito
I'm not sure how a step up converter would help.
I found the charge controller actually only needs 0.1V above the battery voltage, for it to function correctly.
The charge controller is Linear so just dissipates any voltage difference as heat.
I was hoping that the LM2596 would provide a more efficient way to convert from 5V to VBat + 0.2V e.g. from around 3.2 V to 4.4V
However I have been doing some more tests, and the efficiency of the LM2596 is not very good at low currents and low input and output voltages.
From my tests its around 80% (or possibly less) efficient, which makes it only 20% more efficient than the panel its self, which seems to be around %60 efficient at 3V output (compared with its power output at 5V)
The efficiency of my panel seems similar to the graph posted by @steveStrong.
e.g at 3.7V his efficiency was 70% (0.39W instead of max of 0.55W)
As this is only a maximum of 10% worse than using the LM2596, it seems pointless using it
MarkB
Re: Rogers postbag
Post by MarkB » Tue Nov 14, 2017 12:50 pm
The voltage at the maximum power point of a solar cell is proportional with light intensity, but not so strongly that the panel is going to be delivering useful power at very low voltages. For load working voltages in the LiPo range (<=4.2 V) from a nominal 6 V solar panel, I don't think a step up converter ever makes sense. Note that the figure below is a single cell while a nominal 6 V panel is 12 such cells in series.*
I have a little setup that's been running off a solar panel similar using a supercap (4.7 F?) as the power storage element with a zener diode to limit maximum charge voltage. If the application doesn't require a great deal of energy storage, that's probably a simpler approach than most anything involving a battery. The efficiency is sub-optimal of course, especially if the capacitor is significantly discharged between charge cycles.
Coming up with an efficient battery based solution is on my "someday list", but that list grows far faster than items getting checked off.
* - I waffled between 10 and 12 on the number of cells before coming to the realization that both are available on eBay etc. Maybe I'm the last to realize this. I'm pretty sure mine are nominal 6 V panels and 12 cell. The photo Roger posted up thread appears to have 5 V and 10 cells. In any case, that provides a potentially useful free parameter for project design.
Re: Rogers postbag
Post by RogerClark » Tue Nov 14, 2017 7:56 pm
MarkB
Thanks.
I have done a rambling long post on my blog, and my conclusion is that your solution is the best, and even if using a LiPo rather than a supercap it would probably be Ok.
For a LiPo I seem to get good results just be changing the charge current resistor on one of those TP4056 based modules.
As they seem to only need 0.1V above the battery voltage to operate.
I used a 8.6 k resistor in the end, as it gave a reasonable charge current under full sunlight
Re: Rogers postbag
Post by RogerClark » Tue Nov 14, 2017 8:34 pm
BTW.
This thread on Stack overflow has some interesting posts on autoregulating the TP4056
https://electronics.stackexchange.com/q ... extraction
But no one pointed out that its a linear device and its better to go for max current at the voltage required by the battery, rather than maximum power.
Also, no one actually tried a buck converter. But I found they are pointless as the effeciency is 80% at best, which is only marginally better in theory than the panel outputting at a lower voltage.
And in real world usage, the buck converter was far worse.
Re: Rogers postbag
Post by RogerClark » Tue Nov 14, 2017 11:44 pm
BTW.
Someone contacted me via my blog about this module
https://www.ebay.com.au/itm/CN3791-Lith ... 3094202363
So I've ordered some for testing
However, as they cost $3 USD each. which is twice the price of the solar panel, its more cost effective to buy a bigger or better panel than use this module, when the panel only costs around $1
Slammer
Re: Rogers postbag
Post by Slammer » Wed Nov 15, 2017 12:02 am
Roger, watch the video of Andreas Spiess about small solar chargers, you will find measurements for most common modules, is a very good review.
PS. Dont forget to watch and the second video of review : https://youtu.be/ttyKZnVzic4
Re: Rogers postbag
Post by RogerClark » Wed Nov 15, 2017 12:55 am
OK. Thanks
Re: Rogers postbag
Post by ag123 » Fri Nov 24, 2017 1:25 pm
Google ads:
This is off topic, but I'm thinking given the traffic you may like to host google ads, they could in some ways help to lower the cost of running this, just 2c
Re: Rogers postbag
Post by ahull » Fri Nov 24, 2017 2:36 pm
Google ads:
You wont get much revenue from me I'm afraid, my adblocker will bin the ads. :lol:
Re: Rogers postbag
Post by ag123 » Fri Nov 24, 2017 2:40 pm
agree that google ads only pay tiny pennies, a lot of traffic generates only very little revenue, But if there is already quite significant traffic, it may make some difference, not too sure if that would be worth it though.
