[STM32GENERIC] SDIO DMA
danieleff
Re: [STM32GENERIC] SDIO DMA
Post by danieleff » Sat Jun 03, 2017 7:32 am
Pito wrote: I do not know whether the slew rate is the only cause of the issue. When browsing sdio stuff with F4 you may see the most recommended setting is the MEDIUM. And that is the only setting which works with Samsung at 24-33MHz here.
The clocks above 33MHz do not work here either, so still it might be a different issue there as well..
May I ask how do you get more than 24Mhz? According to CubeMX F407 SDIO configuration, "...It is advised to keep the default ClockDiv value (0) to have a maximum SDIO_CK frequency of 24 MHz."
Post by ag123 » Sat Jun 03, 2017 8:22 am
the little secret here is f4 runs at 240mhz (vs 'official' 168mhz) just as capable as the f7, preferably add some vaporizing liquid nitrogen for stability :lol:
http://www.stm32duino.com/viewtopic.php ... 160#p26942
Post by Pito » Sat Jun 03, 2017 9:46 am
You can get almost any SDIO clock, when playing with multipliers and dividers.
Do not use USB but Serial.
For example:
For ag123 as he has got his dewar flask ready
@Daniel: maybe you have to change the dividers in the basic setup with F407 to
/8, *336, /2, /7
as the 1MHz fed into the PLL does suit the datasheet better..
Post by Pito » Sat Jun 03, 2017 10:42 am
This is with Samsung EVO 16GB CL10 and 240MHz_FCPU/34.3MHz_SDIO (all below with the Black F407ZET board):
File size 5 MB
Buffer size 65536 bytes
Starting write test, please wait.
write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
10376.53,27872,5529,6249
10851.28,17714,5529,5971
Starting read test, please wait.
read speed and latency
speed,max,min,avg
14395.19,6292,4515,4557
14395.19,5229,4515,4543
Done
Type any character to start
This is Samsung and 240/40MHz:
FreeStack: 63267
State value (HAL_SD_STATE...): 1
Errorcode value (HAL_SD_ERROR...): 2
R1 value: 100100000000
HAL Return value (HAL_...): 0
C:\Users\pito\MyCode\Arduino\hardware\Arduino_STM32\STM32DE\libraries\SDIO\src\SDIO.cpp
199
readBlocks
Timeout on Read, over 2000ms
Invalid format, reformat SD.
This is a new Sandisk Ultra 16GB CL10, 240/40MHz:
File size 5 MB
speed,max,min,avg
9823.94,39408,5267,6600
10642.60,16345,5266,6081
speed,max,min,avg
16883.85,4677,3864,3884
16941.28,4074,3865,3876
Done
And finally the Sandisk at 240/48MHz SDIO:
FreeStack: 63267
Errorcode value (HAL_SD_ERROR...): 1
R1 value: 1101100000000
HAL Return value (HAL_...): 1
119
begin
Can't access SD card. Do not reformat.
SD errorCode: 0X64,0X0
My feeling is it should work at 50MHz SDIO when the Sdcard set to HighSpeed mode (CMD6), and maybe the "gpio loading cell" activated.. We work here with overclocked stuff so the stm experts will not help with that, sure :)
Post by Pito » Sat Jun 03, 2017 3:48 pm
Sandisk Ultra 16GB CL10, 240/34.3MHz, 1.513GB large file (CRC32 = 06172c89):
Use a freshly formatted SD for best performance..
Opening the read file..
Opening the write file..
Reading and Writing..
Done in 493254 msecs
Running CRC calculations...
File in CRC:  6172C89
File out CRC: 6172C89
Done in 715025 msecs
Sandisk Ultra 16GB CL10, 240/40MHz, 1.513GB large file (CRC32 = 06172c89):
Done in 455700 msecs
Done in 664786 msecs
:ugeek:
Note: Results highly experimental! Do not expect it will work reliably at these settings yet, usually you will get above errors..
Post by zmemw16 » Sat Jun 03, 2017 4:21 pm
any chance of printing the split times separately for the read and write operations?
another - for us plodders with 8MHz and/or 25MHz boards, any chance of a bullet proof slower/much slower set of files ?
some of us don't have the go faster stripes, just your basic blue cz ministm32 f103vet/zet, black 407vet/zet/zgt :roll:
srp
Post by victor_pv » Sat Jun 03, 2017 5:19 pm
Pito wrote:My feeling is it should work at 50MHz SDIO when the Sdcard set to HighSpeed mode (CMD6), and maybe the "gpio loading cell" activated.. We work here with overclocked stuff so the stm experts will not help with that, sure :)
Did you add the CMD6 code? I started writing it but didn't finish, I believe I left at sending the command but still needs to read the response data back.
Post by Pito » Sat Jun 03, 2017 5:34 pm
For experimental purposes the High speed mode with CL10 card is set as follows (in slow clock mode):
1. issue the CMD6 with the argument 0x80000001
SDMMC_CmdSwitchFunction(SDIO, 0x80000001);
2. read dummy 64 bytes off the card
3. issue 1 dummy read
4. now the card is in HS mode.
If you may tell me how it should be done with HAL I will try..
Post by ag123 » Sat Jun 03, 2017 9:17 pm
Wow, 16 MB per secs & it copies 1.5GB in below 8 & 1/3 minutes, fast ethernet definitely cannot catch up u'd need USB 2.0 *high speed* to transceive with the host :lol:
Post by Pito » Tue Jun 13, 2017 6:51 am
Not sure where to place this but let me start here:
I spent last night messing with following issue - Black F407ZET with 512kB External Sram, Heap in the External Sram, SdCard via SDIO, SdFat, basic frequencies.
The "mbmp" allocated in the Heap via malloc(), allocation went fine.
This does not work, it hangs inside the write:
if (myFile.write(mbmp.data, mbmp.size) != mbmp.size) {
    Serial.println(F("### Error writing the file.."));
    return 1;
This write works:
for (uint32_t i=0; i<mbmp.size; i++) {
    myFile.write(mbmp.data[i]);
It worked in past with F103ZET and with the Heap in its External 512kB Sram, SdCard via SPI, SdFat.
