STM35F103VCT6 blink LED issue
HansaG
Post by HansaG »
Hi there,
I'm a quite newbie for the stm32 platform. Rather this is my first attempt at it. So please excuse me.
I'm trying to repurpose a custom board which came for a 3D printer.
schematics https://github.com/bigtreetech/BIGTREET ... %9B%BE.pdf
PCB https://github.com/bigtreetech/BIGTREET ... 9B%BE.docx
So far I was able to;
- Connect to the board via serial
- Use ST demonstrator to fully erase the chip
- Connect to the board via serial through Arduino and upload the blink sketch.
Issue;
- LED blinks a few seconds (5 sec) and stops either in an on or off state.
- LED do not blink continuously.
My guess; (which could be wrong and silly, so pls excuse me) since I did a full erase of the chip, the custom bootloader which was there with the board is erased and Arduino is loading the blink sketch to the bootloader space of the memory.
Kindly help me here and thank you.
ozcar
Answers: 5
Re: STM35F103VCT6 blink LED issue
Post by ozcar »
I'm sort-of wondering if perhaps the original firmware made use of watchdog and this is still getting activated via the option bytes.
I'm not familiar with the "ST demonstrator" that you said you used so I don't know whether you could have "erased" the device without rewriting the option bytes.
Answers: 24
some observations
- it seemed they did not patch the usb connection pin pa11 pa12 and instead used that for the TFT lcd
- the LCD is not documented, only the pins, it sounds like different lcds may be used
- it seemed the uart and jtag pins are accessible, so are the boot0, boot1 pins
in this case, for the STM32, it looks like the main ways to program it is via a ST-Link V2 dongle
or a
3.3v usb-uart dongle using the boot0 pins
https://www.sgbotic.com/index.php?dispa ... page_id=48
there is possibly a custom 'boot loader' installed, but that normally, if you program your sketch using ST-link (i.e. SWD) or usb-uart at 0x8000000 it should overwrite the bootloader.
note that doing this may overwrite the proprietary firmware shipped with the board. If you need that you'd need to check if you can obtain it if you want it back.
heretop
Post by heretop »
I encountered the same problem when I first tried using an STM32 board. It seems your guess is spot on – erasing the chip probably removed the bootloader, and that's why the LED isn't blinking right. I fixed mine by putting a new bootloader on the board before I tried uploading the Blink program again. This made everything work smoothly.
On leds.to, I found a guide that walked me through how to fix the bootloader issue step by step. It was exactly what I needed and helped me get my project back on track.
