I2C alternate pin setting not working on STM32 core (solved)
ManX84
Post by ManX84 »
Hi all!
I have a "generic" board with an STM32F103C8. (I use the last core version and for this version, https://github.com/stm32duino/Arduino_Core_STM32 give version 1.9.0)
On datasheet it is said that for I2C1 I can use PB9 as alternate SDA and PB8 as alternate SCL (confirmed with STM32CUBEmx).
So, with help on I2C example I try this very simple code :
TwoWire WIRE1(PB9,PB8);
void setup(){
  WIRE1.begin(); // join i2c bus (address optional for master)
byte x = 0;
void loop(){
  WIRE1.beginTransmission(4); // transmit to device #4
  WIRE1.write(x); // sends one byte
  WIRE1.endTransmission(); // stop transmitting
  x++;
  delay(200);
I check on Pin PB9 and PB8 with my oscilloscope, nothing happend ! (line stay high, I have 4.6k pull up resistor)
I really not understand where is the problem.. this is very basic code and it must work.. any Id ?
Exposing your opinion is good, exposing your code is better! :mrgreen:
Re: I2C alternate pin setting not working on STM32 core
Last version is 2.6.0. Check the readme of the stm32 core on GitHub to get the new link.
ManX84
Post by ManX84 »
Hello fpiSTM
if you look table https://github.com/stm32duino/Arduino_C ... 2f1-boards
for STM32F103C8 Generic Board, core version =>1.9.0
ManX84
Post by ManX84 »
In fact even standard Wire not working !!
I test all pins listed in PeripheralPins.c for my STM32 variant !!
Link is https://raw.githubusercontent.com/stm32 ... index.json
It exists since several years. And stay calm, please.
I know wire works as it was tested several times per week. I will help you tomorrow as since 2.0.0 the way to use pins is different thanks the _ ALTx suffix.
ManX84
Post by ManX84 »
If I look to my Package, I have:
...\packages\STMicroelectronics\hardware\stm32\2.6.0
So correction, I am in the last core version
Well, I've tested and have correct result:
Are you sure you have well wired PU resistors on each I2C Line.
Select the correct board in the menu: Generic F1, then Generic F103C8 or BluePill F103C8
ManX84
Post by ManX84 »
Hello fpiSTM.
I just try to make a really short test (1 byte sending in while loop) with keil uVision and STM32CUBEmx and it work like that, I have the clock on my oscilloscope !
Select the correct board in the menu: Generic F1, then Generic F103C8 : YES, I have generic F103C8 selected!
Could you send me your .hex I will try it ?
If it work this mean that I have a problem with my arduino IDE configuration (I run the last V2)
Very strange !
ManX84
Post by ManX84 »
Here my full code, just to be sure.
// I2C Test on STM32F108C
// core STM32 2.6.0
// https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json
TwoWire WIRE1(PB9, PB8);
 WIRE1.setClock(400000); //400khz frequency
byte x = 0;
      x++;
      delay(100);
  }while(1);
I know the loop() is already a while, but just to be sure there are no mistake.. add my own while loop.
Could you try this exact code ?
Thanks for your help!
ManX84
Post by ManX84 »
I am now sure the ide use my STM32 package (I had an incorrect line on the Wire.h from the ...\AppData\Local\arduino15\packages\STMicroelectronics\hardware\stm32\2.6.0\libraries\Wire\src\ directory, and I have an error in the IDE console when compiling!
Here my board configuration:
IDE_CONFIG (Petit).jpg (58.76 KiB) Viewed 1153 times
Really don't understand where is the trap..
