[STM32GENERIC] F746 Discovery
danieleff
Re: [STM32GENERIC] F746 Discovery
Post by danieleff » Mon Jul 24, 2017 4:28 am
    SerialUART6.begin(115200);
    SerialUART6.println(millis());
pin 0/1
oneselflost
Post by oneselflost » Mon Jul 24, 2017 11:10 pm
Thank you Danieleff for replying.
I tried your suggestion and it landed me with:
"exit status 1
'SerialUART6' was not declared in this scope"
That said, after updating my STM32GENERIC file to the latest variants, the sketch compiles with no issues.
EDIT - The sketch compiles and uploads, but the serial tx does not tx any logical data. Everything I sniffed the serial output with returned gibberish. I will continue playing with this.
Thank you for getting me on my feet with this!
Post by zmemw16 » Tue Jul 25, 2017 1:00 pm
try changing the serial monitor baud rate :!:
click on button down to the bottom right
better - locate Setup procedure/function in your sketch, in it you should see a line with ".begin(9600)" in it
it might be 19200, 38400, 57600, 115200
oneselflost
Post by oneselflost » Tue Jul 25, 2017 2:54 pm
Hi zmemw,
Baud rate was the first thing I checked. Everything is set to 115200.
I used an Arduino Uno initially as a serial receiver, but no luck there.
I also used an FTDI Basic with both the Arduino serial monitor, as well as PuTTY.
It's gotta be something I'm doing wrong, can't imagine its the board or repository.
I have an xbee explorer which works well as a serial monitor. TeraTerm might be another alternative.
Looking forward to getting home to tinker with it a bit more.
oneselflost
Post by oneselflost » Wed Jul 26, 2017 2:07 pm
Got it!
so having Serial.begin(115200); AND "SerialUART6.begin(115200);" was causing issues. As soon as I commented out the Serial.begin line, UART6 worked perfectly.
That said, I am over the moon happy!
Thanks everyone for the help! :D
ChrisMicro
Post by ChrisMicro » Wed Aug 09, 2017 9:04 am
Finally it seems that there is now "Ethernet" somehow implemented:
https://github.com/danieleff/STM32GENER ... G/Ethernet
But unfortunately it is not working for 2 reasons:
1. The file ending of the example is *.txt insteat of *.ino which prevents the Arduino IDE from loading the example
2. The driver is not found when the example is named correctly.
danieleff
Post by danieleff » Wed Aug 09, 2017 1:30 pm
It uses drivers the official drivers Frederic talked about here: viewtopic.php?f=51&t=2220&start=10#p31084
They are still under pull request. The top of the example file has comments on how to install. They are in a different repo + branch, so you cannot just download it from github as zip.
Post by fpiSTM » Wed Aug 09, 2017 2:44 pm
I'm currently under test before merge the PR.
ChrisMicro
Post by ChrisMicro » Wed Aug 09, 2017 2:50 pm
Hi Daniel,
I saw you put a lot of drivers in the repo. In my opinion that is a good idea to get a complete working environment even it is a little bit cumbersome to keep the libraries up to date. As far as I know Roger does this in his repo too.
From time to time I'm looking on the new things you did, pull it and try it. This time I realized that the ethernet example was not working and my old example for the SD-card is also not working. Probably for this cases it would be the best to have a development branch where this preliminary versions reside.
What are your plans for the ethernet? Will the driver be included?
Cheers,
Chris
ChrisMicro
Post by ChrisMicro » Wed Aug 09, 2017 2:51 pm
Does this mean the Generic-repo and the STM-repo is merging to one repo?
