[STM32GENERIC] SerialUSB Print(F( speed and availableForWrite()
Post by Pito » Sun Jun 18, 2017 4:00 pm
While messing with the Zmodem example:
1. we miss the Serial.availableForWrite() method
2. when I look at the SerialUSB speed while printing out a bunch of strings (via Serial.print(F(..)) ) my impression is it runs like 9k6, I would guess it should be the fastest mode we've got.. Maybe I do something wrong?
Re: [STM32GENERIC] SerialUSB speed and availableForWrite()
Post by Pito » Sun Jun 18, 2017 4:59 pm
This is a bench for the Serial.print(F()) via SerialUSB (168MHz F407ZET):
UPDATE: println(F( vs. println(
// Serial.print(F()) via SerialUSB benchmark
// Pito 6/2017
  delay(3000);
  uint32_t elapsed = micros();
  for (uint32_t i = 0; i < 20; i++) {
    Serial.println(F("THIS IS A TEST THIS IS A TEST THIS IS A TEST THIS IS A TEST THIS IS A TEST"));
  elapsed = micros() - elapsed;
  Serial.print("Elapsed with (F(: ");
  Serial.print(elapsed);
  Serial.println(" usecs");
  Serial.println(" ");
  elapsed = micros();
    Serial.println("THIS IS A TEST THIS IS A TEST THIS IS A TEST THIS IS A TEST THIS IS A TEST");
  Serial.print("Elapsed: ");
Result:
Elapsed with (F(: 1496123 usecs
Elapsed: 39971 usecs
danieleff
Post by danieleff » Sun Jun 18, 2017 5:07 pm
F407VE
Elapsed: 198278 usecs
Post by Pito » Sun Jun 18, 2017 5:09 pm
That is 8x faster.. :(
My clocks config:
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLQ = 7;
My usb stuff is from May 13th 2017.
Post by Pito » Sun Jun 18, 2017 5:42 pm
Can somebody try under Win7, plz?
Post by stevestrong » Sun Jun 18, 2017 6:46 pm
not generic, but just as comparison to libmaple F407Vet6:
Elapsed: 484 usecs
But we have 2*2kB buffer...
Post by Pito » Sun Jun 18, 2017 6:59 pm
That is 3100x faster that mine.. So it seems it is something wrong with my F407ZET's SerialUSB then :D
Post by Pito » Mon Jun 19, 2017 10:39 am
I've updated the benchmark above and:
1. with Serial.println("THIS.. it takes 39971 usecs
2. with Serial.println(F("THIS.. it takes 1496123 usecs
So it seems the "F" is the issue here.. (Black F407ZET)
Post by Pito » Tue Jun 20, 2017 11:57 pm
@Daniel and Steve: I do not understand how you can get such speeds with printing with "F".
When stepping with debugger through it, the "F" prints each char individually via USB (after each write(c) below I see a new char appears in the TeraTerm terminal)
size_t Print::print(const __FlashStringHelper *ifsh)
  PGM_P p = reinterpret_cast<PGM_P>(ifsh);
  size_t n = 0;
  while (1) {
    unsigned char c = pgm_read_byte(p++);
    if (c == 0) break;
    if (write(c)) n++;
    else break;
  return n;
which multiplied by 1ms gives the number above (==76*20*1ms = around 1500ms), while the standard print passes the pointer of the string buffer and its size to an USB tx routine, and the buffer is then txed via USB in one shot (~20x 1ms).
Or, am I using a wrong core lib? :?
danieleff
Post by danieleff » Wed Jun 21, 2017 4:31 am
Libmaple has optimizes version of it
  return print(reinterpret_cast<const char *>(ifsh));
I only just used the vanilla arduino one with the loop. (Edit: I do not know why my was faster than your actually.)
