[STM32GENERIC] F429i Discovery
danieleff
Re: [STM32GENERIC] F429i Discovery
Post by danieleff » Wed Jul 12, 2017 3:01 pm
With some PinMap magic glue code, ethernet compiles, just
WARNING: library LwIP claims to run on [stm32] architecture(s) and may be incompatible with your current board which runs on [STM32] architecture(s).
WARNING: library STM32Ethernet claims to run on [stm32] architecture(s) and may be incompatible with your current board which runs on [STM32] architecture(s).
I will rename the main folder from STM32 to stm32.
Other than that, I think libraries can work on both cores.
Post by zmemw16 » Wed Jul 12, 2017 4:15 pm
aren't those from the library.properties file ?
add ',stm32' to the architectures line
Post by fpiSTM » Wed Jul 12, 2017 5:04 pm
it's case sensitive ;) maybe we could add ',STM32' in the library.properties
Fine if it's both compatible. That's why I would like one repo for each lib and not integrate it in the core ;)
ChrisMicro
Post by ChrisMicro » Sat Sep 16, 2017 6:39 am
Because daniel has meanwhile done some work for the F429 disco, I added a TFT voltmeter example.
It reads the voltage from PA0 and displays it. PA0 is connected to the blue button of the board. I you press the button the displayed voltage changes to 3.3V.
I have tried other pins e.g. PA1 but there seems to be a driver problem. PA1 shows always '0'.
ChrisMicro
Post by ChrisMicro » Mon Sep 18, 2017 8:35 pm
I tried to find the touch controller which should be connected to I2C3 with the scanner.
But it does not respond. So either there is a fault in my scanner configuration or there is a problem with the I2C3 implementation.
Because I tried to measure the I2C3 signals wiht the oscilloscope on PA8 and PC9 and there where no signaIs, I think there is a problem with the I2C implementaion
Anny idea?:
#define SERIALINTERFACE Serial
  //Wire.begin();
  Wire.stm32SetInstance(I2C3);
  Wire.stm32SetSDA(PC9);
  Wire.stm32SetSCL(PA8);
  //enableDevices();
  SERIALINTERFACE.begin(115200);
  delay(5000);
  SERIALINTERFACE.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  SERIALINTERFACE.println("Scanning...");
  delay(2000);
  nDevices = 0;
  for (address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    Wire.write(0);
    error = Wire.endTransmission();
    if (error == 0)
      SERIALINTERFACE.print("I2C device found at address 0x");
      if (address < 16)  SERIALINTERFACE.print("0");
      SERIALINTERFACE.print(address, HEX);
      SERIALINTERFACE.println("  !");
      nDevices++;
    else if (error == 4)
      SERIALINTERFACE.print("no device found at address 0x");
      SERIALINTERFACE.println(address, HEX);
  if (nDevices == 0)
    SERIALINTERFACE.println("No I2C devices found\n");
    SERIALINTERFACE.println("Did you configure the chip select for your device?\n");
  else
    SERIALINTERFACE.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
TFTLCDCyg
Post by TFTLCDCyg » Mon Sep 18, 2017 9:33 pm
In the same line that the ChrisMicro question, about the F429I-DISCO board:
Is it possible to remap the full GPIO with STM32CubeMX in order to activated I2C2, I2C3, SDIO, SPI4, SPI5 or SPI6 for example?
danieleff
Post by danieleff » Tue Sep 19, 2017 5:11 am
1. Is it an already existing library that is not written by you, that is dumb and only knows about the first instance of Wire?
    DumbLibrary.begin(); // dumb library does not know that the chip has multiple I2C, and thinks there is only Wire. What a shame... READ THE LIBRARY DOCUMENTATION
    // THE PREVIOUS LINE WILL CALL Wire.begin() !!!
2. Is it an already existing library not written by you, that knows that there are multiple I2C ports on the chip?
TwoWire MyWire(I2C3, PC9, PA8);
    SmartLibrary.begin(&MyWire); // Smart library knows that there are chips with multiple I2C ports. Nice! READ THE LIBRARY DOCUMENTATION
    // the previous line will call MyWire.begin() probably...
3. You yourself are calling the Wire.xxx methods yourself?
    MyWire.begin();
    // Do whatever with MyWire
Ditto for SPI.
Chris you forgot to call Wire.begin() after changing the pins, but it would be better to use the 3rd option for non-first I2C, whenever you can get away with it.
ChrisMicro
Post by ChrisMicro » Tue Sep 19, 2017 12:30 pm
Damn it .. I looked 10 times and didn't see :(
But thanks :D
Here I made the new TFT touch screen example
