[STM32GENERIC] Latest - issues
Re: [STM32GENERIC] Latest - issues
Post by stevestrong » Sun Jun 25, 2017 4:48 pm
For F1 one need "VERY_HIGH" (50MHz) GPIO speed, otherwise SPI@36MHz won't work.
Btw, I think the GPIO speed setting was set to "MEDIUM" due to Pito's recommendation for F4 SDIO to work.
Well, SDIO works for libmaple F4 with GPIO set to push-pull with enabled pull-up and the default push-pull speed "HIGH" (50MHz).
Post by Pito » Sun Jun 25, 2017 6:13 pm
Trust, but verify :)
Here with VERY_HIGH gpio speed at SPI 36MHz, Samsung:
Use a freshly formatted SD for best performance..
Opening the read file..
Opening the write file..
Reading and Writing..
Done in 89378 msecs
Running CRC calculations...
File in CRC:  22483A52
File out CRC: 22483A52
Done in 227120 msecs
File size 5 MB
Buffer size 512 bytes
Starting write test, please wait.
write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
3313.24,16622,144,152
3315.44,16601,144,152
3282.78,19821,144,153
Starting read test, please wait.
read speed and latency
speed,max,min,avg
3113.13,1503,161,162
3115.07,1397,161,162
3115.07,1394,161,162
Done
Seems the numbers a little bit lower than with Victor's SPI DMA in past (3566/3163)..
And with 44MHz SPI Samsung:
File size 5 MB
speed,max,min,avg
4229.85,9345,115,119
4244.21,9112,115,119
4291.57,7318,115,117
speed,max,min,avg
3822.39,989,132,132
3822.39,858,132,132
3819.47,860,132,132
Done
Sandisk 4050/3819. Interestingly Sandisk works now at 44MHz.
The SPI 48MHz throws above error for both cards.
PS: Let F407 SDIO at MEDIUM..
Post by Pito » Sun Jul 16, 2017 7:23 am
These are 2 issues I see here with USB with the latest (local repo updated here on 24.6.) on Blue F103ZET board:
1. with the latest when compiled for SerialUSB the SerialUSB console is not recognized by Win7.
The upload via DFU works.
2. The SerialUSB is recognized when compiled with my previous local repo version and it works, but with the TX speed issue (there is the old CDC ACM driver used - it has to be patched with Steve's patch - https://github.com/stevstrong/Arduino_S ... 7d2281eadb ).
danieleff
Post by danieleff » Sun Jul 16, 2017 1:14 pm
Does it work with bluepill?
Not recognized means the yellow triangle in device manager? If so, try changing the USBD_VID to 0x1EAF, and USBD_CDC_PID_FS to 0x0004
Post by Pito » Sun Jul 16, 2017 1:37 pm
It does work with MapleMini and the latest, connected via COM4 STM32 Virtual port. I do not have BP handy today.
It does work with Black F407ZET and the latest, connected via COM4 STM32 Virtual port.
There is the USBSerial TX issue, however (82x slower than normal).
The Blue F103ZET and the latest - I get a bubble message "USB device not recognized" when inserted the USB, with "Unknown device" in the DevMan, none yellow triangle in the DevMan.
Post by Pito » Sun Jul 16, 2017 4:40 pm
In the platform.txt there is several times used the flag
-DARDUINO_ARCH_{build.arch}
and maybe it shall produce something like -DARDUINO_ARCH_STM32, but it does not, at least here.. :(
My folder with the latest repo is called "STM32DE1", and what I see in the compiler's log is
.../4.8.3-2014q1/bin/arm-none-eabi-gcc" -mcpu=cortex-m3...
... -DSTM32F1 -DARDUINO=10802 -DARDUINO_BLUE_F103XX -DARDUINO_ARCH_STM32DE1 -DSTM32F103ZE
and it is obviously not good to get.. Btw, we use the flag in SdFat..
The same in libmaple..
danieleff
Post by danieleff » Sun Jul 16, 2017 5:48 pm
Rename your STM32DE1 folder to STM32, the folder name is the way to distinguish between multiple archs.
I will not be able to fix the USB issue with F103ZET, it should work as the code is the same as F103C. The difference is only clock setup, and maybe it has a USB_DISC_PIN.
Post by Pito » Sun Jul 16, 2017 6:22 pm
:twisted: You are right, I messed with clock settings in variant.c.. I had 7 there.. :cry:
Now the F103ZE connects.. Thanks.
What about the USBSerial Tx patch - your core is using different files as the libmaple, it seems..
I patched the libmaple core today - https://github.com/stevstrong/Arduino_S ... 7d2281eadb
and the Tx speed went from 9k6 to ~1000k.. Your core is 9k6..
The -DARDUINO_ARCH flag - I think it is a bad idea to derive the architecture name based on the repo folder's name.. :?
I will hard-wire it ARDUINO_ARCH_STM32 here in my platform.txt, as I am using 8 folders for various repos (and their different versions) here.
And Roger has in his libmaple the folders called STM32F1, STM32F3, STM32F4 in there - and the arch is ARDUINO_ARCH_STM32 (at least SdFat is using that flag).
Moreover, everything in stm32duino is _STM32 architecture.. :)
vitor_boss
Post by vitor_boss » Tue Aug 01, 2017 12:21 am
Serial.available() is not working properly.
My code use a lot of that to check list of commands, but it is currently return a Bool result instead number of bytes
Actual code:
int SerialUART::available() {
    return rxEnd != rxStart;
I have changed to that but I'm not sure if is right, but is working:
    int result = rxEnd - rxStart;
    if(result == BUFFER_SIZE) { return 0; }
    else { return result; }
That is on file SerialUART.cpp
