STM32GENERIC Arduino implementation
danieleff
Post by danieleff » Wed Jul 05, 2017 11:38 am
STM32GENERIC: Arduino implementation on top of STM32 HAL, for all STM32 boards.
Code on GitHub: https://github.com/danieleff/STM32GENERIC
Documentation: https://danieleff.github.io/STM32GENERIC/
Installation instructions: https://danieleff.github.io/STM32GENERIC/
For submitting problems, please use GitHub Issues: https://github.com/danieleff/STM32GENERIC/issues
For some usage examples, check in the Arduino IDE, menu File=>examples=>STM32 board examples for users
This is an alternative to the official implementation: https://github.com/stm32duino/Arduino_Core_STM32, it should be very similar in Arduino API, and STM32 HAL API.
danieleff
Re: STM32GENERIC Arduino implementation
Post by danieleff » Sun Jul 16, 2017 5:23 am
Given that the main focus is on libmaple and the official implementation,this takes a turn the following way.
The focus is on experimental, non-essential stuff.
You can create libraries for peripherals as their own repo, if you use HAL, both official and this can use them. (If it works, I can add it to board examples (as in, download X library from here: ...)) (I will also create some of these, if nobody else does)
Almost all of Arduino API works, I want to work on fun stuff that need support from the core:
  • libmaple-compatible HardwareTimer, and extend it to more timer modes
  • Extend AN2594 to variable size data (1-512 bytes), and multiple-pages, for EEPROM emulation, and...
  • ...use the previous point for flash disk emulation with on-chip flash, and as a mass storage drive backend
  • Virtual file system, like in ESP32.
  • analogRead starts DMA read, and all subsequent reads only read from the dma-buffer
  • Add weak mutex API to transactions for SPI/I2C/SDIO, implement in FreeRTOS, for thread safe access of same peripheral
  • Clock API, common defaults for most used clocks, common ldscripts. The variant folder will only contain variant.h.
  • DFU for F407?
  • delay() puts the MCU to sleep??
So stuff almost nobody uses, it should not change the Arduino API.
There won't really be branches, just the master, as nobody would test non-master anyway. It might break compilation for some chips, but I want this to be fast moving. The other cores might give you a more stable experience.
Post by RogerClark » Sun Jul 16, 2017 6:11 am
Daniel
You can use the github Releases system if you want to mark a particular commit as being relatively stable ;-)
ChrisMicro
Post by ChrisMicro » Sun Jul 16, 2017 6:34 am
I don't understand exactly how you mean it. Can you describe the procedure?
danieleff
Post by danieleff » Sun Jul 16, 2017 1:52 pm
Daniel
Yes I will have to think about it.
Just a github repository with a library.properties file in root, and the source in src folder.
ChrisMicro
Post by ChrisMicro » Mon Jul 17, 2017 4:38 am
My fear is a little bit that the whole system becomes a little bit inconvenient if you have to download "one zillion" of libraries before you can try to use any example.
Your argument that the libraries can be used from different base frameworks has to be taken into account.
But how can we keep the Arduino 3 step principle of
1. download
2. choose example
3. press compile and flash
when you first have to look for a lot of libraries?
Post by zmemw16 » Mon Jul 17, 2017 12:46 pm
1.stop ide
2.download and install libraries or clone repo's into sketchbook/libraries, issue with updating one as git refuses to overwrite?
3.restart ide to refresh the libraries it sees
ChrisMicro
Post by ChrisMicro » Mon Jul 17, 2017 1:03 pm
Yes, but the problem e.g.
You have a STM32F746 Discovery, you need a lot of drivers:
- touch
- TFT
- Microphone
- Ethernet
- Sound out
This means searching, finding ... not working on the first click
Post by zmemw16 » Mon Jul 17, 2017 1:09 pm
surely that's precisely the current state, Adafruit_XXX needs Adafruit_GFX etc.
i've installed a few others as well and have had to go round that loop more than once as then some of the 'needed' libraries have their own 'needs', so reading the source of the original set is not always enough to detail them all.
danieleff
Post by danieleff » Mon Jul 17, 2017 1:28 pm
I might make the STM32-only libraries as git submodules, and pack into the board manager package.
