AT24C32 not able to write in Test Program for STM32F103C8T6
asking
Post by asking »
I have tried below code to test the simple byte function and read the same.
Circuit is connected to port and I2C Scanner is detecting Chip @ 0x50 Address. Working @ 3.3V. WP on AT24C32 Pin is left open.
What else could be issue ?
#define EEPROM_ADDRESS 0x50 // I2C address of the EEPROM
  Wire.begin();
void writeByteToEEPROM(byte data, int address) {
  Wire.beginTransmission(EEPROM_ADDRESS); // Start communication with the EEPROM
  Wire.write(address >> 8); // Send high byte of the address
  Wire.write(address & 0xFF); // Send low byte of the address
  Wire.write(data); // Send data byte
  Wire.endTransmission(); // End communication with the EEPROM
byte readByteFromEEPROM(int address) {
  byte data = 0;
  Wire.endTransmission(false); // End transmission with repeated start
  Wire.requestFrom(EEPROM_ADDRESS, 1); // Request 1 byte from the EEPROM
  if (Wire.available() >= 1) {
    data = Wire.read(); // Read data byte
  return data;
  byte dataToWrite = 42; // Byte data to write to the EEPROM
  int addressToWrite = 0; // Address in the EEPROM where you want to write the byte
  writeByteToEEPROM(dataToWrite, addressToWrite); // Write the byte to the EEPROM
  // Read the byte back from the EEPROM for verification
  byte readData = readByteFromEEPROM(addressToWrite);
  Serial.print("Data written to EEPROM: ");
  Serial.println(dataToWrite);
  Serial.print("Data read from EEPROM: ");
  Serial.println(readData);
Answers: 8
Re: AT24C32 not able to write in Test Program for STM32F103C8T6
Which core do you use?
Which board have you selected in the Arduino IDE?
asking
Post by asking »
In Arduino its showing as
STM32F1XX/GD32F1XX Boards by stm32duino.
I have Selected Generic STM32F103C6/fake STM32F103C8T6
Answers: 8
OK, @fpiSTM should be able to give you more support.
Answers: 91
Unfortunately not. This menu is not in the stm32 core.
Answers: 8
@asking which core do you use?
How did yo get this board in Arduino boards menu?
Answers: 91
@stevestrong
This menu is part of the libmaple core:
https://github.com/rogerclarkmelbourne/ ... s.txt#L446
Answers: 8
fpiSTM wrote: Wed Feb 14, 2024 1:29 pm @stevestrong
That is true, just that
is not known.
@asking supposed it is the Libmaple core, what exactly is not working?
Please select "Generic STM32F103C" as board from Arduino menu and check again.
@fpiSTM could you eventually move this post under Cores -> Libmaple?
Answers: 91
stevestrong wrote: Wed Feb 14, 2024 1:42 pm
is not known.
Guess it is linked to dandrown package json file.
stevestrong wrote: Wed Feb 14, 2024 1:42 pm @fpiSTM could you eventually move this post under Cores -> Libmaple?
Already done :mrgreen:
