STM32F746G and Interrupt Pin?
nathanS
Post by nathanS » Fri Jul 14, 2017 3:02 pm
Hi I am trying to get the following code below, which works fine on an Uno R3 to work correct on a STM32F746G I had lying around. The speed of the motor can be change, but the rpm measurement doesn't work at all. I made sure to wire the rpm sensor to the 3.3v on the board.
simple program for controlling the SCK-200 and reading the rpms
code example taken from
http://www.instructables.com/id/How-to- ... h-Arduino/
#include <Servo.h>
// initialize the Servo object
Servo ESC1;
int RPM_RESOLUTION = 20;
int rpmPin = 2;
int rpmValue = 0;
int rpm = 0; // the desired rpm value
int rmc = 0; // keep track of how many times we measured the rpm
int pwm = -1;
int pole_revolutions = 0; // couints the number of resolutions
unsigned long timeold = 0;
void setSpeed(int ms) {
ESC1.writeMicroseconds(ms);
pinMode(rpmPin, INPUT_PULLUP);
//digitalWrite(rpmPin, HIGH); // inable the pullup resistor
ESC1.attach(10); // attach the ESC to pin 10
setSpeed(1000); // arm ESC
// used for rpm measurement
attachInterrupt(0, rpmFun, FALLING);
// set the speed range
//setSpeed(2000);
Serial.println("Turn On ESC");
delay(5000);
Serial.println("ESC ARMED");
// first get the speed in rpms
if (Serial.available() > 0) {
int input = Serial.parseInt();
rmc = 0; // reset this to zero
if (input > 0) {
rpm = input;
Serial.print("Speed set to: ");
Serial.println(rpm);
pwm = getSpeedPWM(rpm); // get a rouch estimate of speed
Serial.print("PWM: ");
Serial.println(pwm);
if (pwm > 1000 && pwm < 2000) {
setSpeed(pwm);
} else if (input == -1) {
Serial.println("\nMotor Stopped\n");
setSpeed(1000);
// get the desired rpm and set speed
if (pole_revolutions >= 70) {
rmc++;
detachInterrupt(0);
rpmValue = 8.6 * 1000 / (millis() - timeold) * pole_revolutions;
timeold = millis();
// print out the rpms
Serial.print("Measured RPM: ");
Serial.println(rpmValue);
if (rmc > 2) {
int npwm = computeNewPWM(pwm, rpm, rpmValue);
if (npwm != 0) {
Serial.print("Corrected PWM: ");
Serial.print(pwm);
Serial.print(" -> ");
Serial.println(npwm);
pwm = npwm;
setSpeed(pwm);
int computeNewPWM(int pwm, int rpm, int rpmValue) {
int diff = rpmValue - rpm;
int adiff = fabs(diff);
if (diff > 0 && adiff > RPM_RESOLUTION) {
return pwm - 2;
} else if (diff < 0 && adiff > RPM_RESOLUTION) {
return pwm + 2;
} else {
return 0;
// get the speed pwm given a certain rpm
int getSpeedPWM(int rpm) {
long crpm = 0;
int p = 0;
for (p = 1000; p <= 2000; p++) {
//int crpm = -21457 + 28 * pww + -0.007 * square(pwm);
crpm = -29334L + 39L * p + -0.01 * pow(p, 2);
//Serial.println(crpm);
if (fabs(rpm - crpm) < RPM_RESOLUTION * 2) {
break;
return p + 5; // set to lower speed
//Each rotation, this interrupt function runs 7 times for the 7 poles of the motor
void rpmFun() {
pole_revolutions++;
danieleff
Re: STM32F746G and Interrupt Pin?
Post by danieleff » Fri Jul 14, 2017 4:16 pm
Just guessing but maybe you wrote `attachInterrupt(0, `, and used pin 2, that is interrupt 0 on UNO.
STM32 has interrupts on every pin, so `attachInterrupt(0`= pin 0.
(If still it does not work, I can check on weekend)
Post by zmemw16 » Fri Jul 14, 2017 4:25 pm
please enclose code with the </> button
this is code and is so much more readable
nathanS
Post by nathanS » Fri Jul 14, 2017 4:31 pm
Thanks Daniel. That was the problem. It works fine now after attaching interrupt to the same pin.
