[STM32GENERIC/HAL] SerialUSB TX/RX speed problem
Re: [STM32GENERIC/HAL] SerialUSB TX/RX speed problem
Post by Pito » Thu Aug 24, 2017 7:06 pm
@daniel: Interesting! My hypothesis: by running the above test (mersenne CPU stress test) you are heating up the internal temperature in your box such your usb subsystem works better (ie usb clock??, voltages??).
danieleff
Post by danieleff » Fri Aug 25, 2017 5:11 am
Using this code https://stackoverflow.com/a/6037377/834966, with larger `buffer[1024]`
* original tight loop: all data received
* `Sleep(10/100/1000)` in the loop: losing same amout(!) of data. (The TX timeout in arduino code is commented out, blocking all the way!)
Code from first post on Tennsy 3.5 in TeraTerm: losing some data.
I start to suspect it is usbser.sys. Are there any alternative drivers? I will need to run a linux live CD on this machine.
(I also get 128/256 buffer 3sec problem, but that will be something else entirely.)
Post by Pito » Fri Aug 25, 2017 6:43 am
In a discussion I've seen they recommend WinUSB instead of usbser.sys..
