(Solved) STM32F765zg, can get even the simples usb test to work
Spawn32
Post by Spawn32 » Tue Nov 21, 2017 2:05 am
Got blink test running but can make my usb work at all, dosen show up on my computer, nothing :)
If i compile a test prog with the st's tools it work straight a way :/
Is there something spesial i need to do when compiling for the F7 under arduino stm32generic ?
have updated compiler version for F7 and get no errors...
This is the simple prog:
  SerialUSB.begin(9600); // Initialize Serial Monitor USB
  while (!SerialUSB) ; // Wait for Serial monitor to open
  // Send a welcome message to the serial monitor:
  SerialUSB.println("Send character(s) to relay it over Serial");
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  SerialUSB.println("I am Alive :)");
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
If i remove the while (!SerialUSB) ; // Wait for Serial monitor to open it starts it's led blink.
This is the board i added:
boards.txt
# The Borg board
BORG_F765.name=The Borg
BORG_F765.upload.maximum_size=1048576
BORG_F765.upload.maximum_data_size=524288
BORG_F765.build.core=arduino
BORG_F765.build.board=BORG_F765
BORG_F765.build.mcu=cortex-m7 -mfpu=fpv4-sp-d16 -mfloat-abi=hard
BORG_F765.build.series=STM32F7
BORG_F765.build.variant=BORG_F765
BORG_F765.build.extra_flags=-DSTM32F765ZG -DHSE_VALUE=12000000
BORG_F765.build.f_cpu=216000000L
BORG_F765.upload.protocol=STLink
BORG_F765.upload.tool=stlink_upload
BORG_F765.menu.upload_method.STLinkMethod=STLink
BORG_F765.menu.upload_method.STLinkMethod.upload.protocol=STLink
BORG_F765.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
BORG_F765.menu.upload_method.serialMethod=Serial UART1 [TX/PA9, RX/PA10, BOOT0=1, BOOT1=0]
BORG_F765.menu.upload_method.serialMethod.upload.protocol=maple_serial
BORG_F765.menu.upload_method.serialMethod.upload.tool=serial_upload
BORG_F765.menu.upload_method.serialMethod.build.extra_flags_serial_auto=-DMENU_SERIAL_AUTO=SerialUART1
BORG_F765.menu.upload_method.DFUUploadMethod2=USB DFU - Custom bootloader (0x10000)
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.protocol=pico_upload
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.tool=pico_upload
BORG_F765.menu.upload_method.DFUUploadMethod2.build.extra_flags=-DSTM32F446VE -DVECT_TAB_OFFSET=0x10000 -DHSE_VALUE=12000000
BORG_F765.menu.upload_method.DFUUploadMethod2.build.ldscript=ldscript_bootloader_10000.ld
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.usbID=0483:df11
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.altID=2
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.maximum_size=458752
BORG_F765.menu.upload_method.DFUUploadMethod2.upload.maximum_data_size=131072
BORG_F765.menu.upload_method.DFUUploadMethod2.build.extra_flags_serial_auto=-DMENU_SERIAL_AUTO=SerialUSB
BORG_F765.menu.usb.SerialUSB=Serial [Virtual COM port, PA11/PA12 pins]
BORG_F765.menu.usb.SerialUSB.build.extra_flags_usb=-DMENU_USB_SERIAL
BORG_F765.menu.usb.Disabled=Disabled, no USB
BORG_F765.menu.serial.Automatic=Automatically selected based on upload method
BORG_F765.menu.serial.SerialUSB=SerialUSB
BORG_F765.menu.serial.SerialUSB.build.extra_flags_serial=-DMENU_SERIAL=SerialUSB
BORG_F765.menu.serial.SerialUART1=SerialUART1
BORG_F765.menu.serial.SerialUART1.build.extra_flags_serial=-DMENU_SERIAL=SerialUART1
platform.h is the normal that follows STM32generic.
Variant.c includes the working clock setup from my st files:
Setup for 216mhz from a 12mhz crystal..
#include "stm32_build_defines.h"
#include "stm32_def.h"
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.PLL.PLLM = 6;
  RCC_OscInitStruct.PLL.PLLN = 216;
  RCC_OscInitStruct.PLL.PLLQ = 9;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  HAL_PWREx_EnableOverDrive();
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_UART4
                              |RCC_PERIPHCLK_UART5|RCC_PERIPHCLK_I2C1
                              |RCC_PERIPHCLK_CLK48;
  PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInitStruct.Uart4ClockSelection = RCC_UART4CLKSOURCE_PCLK1;
  PeriphClkInitStruct.Uart5ClockSelection = RCC_UART5CLKSOURCE_PCLK1;
  PeriphClkInitStruct.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
  PeriphClkInitStruct.Clk48ClockSelection = RCC_CLK48SOURCE_PLL;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
and here is the variant.h
ifndef VARIANT_H
#define VARIANT_H
#define LED_BUILTIN PA2
#define STM32_LED_BUILTIN_ACTIVE_HIGH
#define MOSI PE14
#define MISO PE13
#define SCK PE12
#define SS PA4
#define SDA PB9
#define SCL PB8
#define A0 PC3
#define A1 PC2
#define A2 PC1
#define A3 PC0
#define A4 PE3
#define A5 PE4
#define EEPROM_BLOCK_0_SECTOR    6
#define EEPROM_BLOCK_1_SECTOR    7
#define EEPROM_BLOCK_0_SIZE      128
#define EEPROM_BLOCK_1_SIZE      128
#define VARIANT_PIN_LIST \
   PIN(A,0), \
   PIN(A,1), \
   PIN(A,2), \
   PIN(A,3), \
   PIN(A,4), \
   PIN(A,5), \
   PIN(A,6), \
   PIN(A,7), \
   PIN(A,8), \
   PIN(A,9), \
   PIN(A,10), \
   PIN(A,11), \
   PIN(A,12), \
   PIN(A,13), \
   PIN(A,14), \
   PIN(A,15), \
   PIN(B,0), \
   PIN(B,1), \
   PIN(B,2), \
   PIN(B,3), \
   PIN(B,4), \
   PIN(B,5), \
   PIN(B,6), \
   PIN(B,7), \
   PIN(B,8), \
   PIN(B,9), \
   PIN(B,10), \
   PIN(B,11), \
   PIN(B,12), \
   PIN(B,13), \
   PIN(B,14), \
   PIN(B,15), \
   PIN(C,0), \
   PIN(C,1), \
   PIN(C,2), \
   PIN(C,3), \
   PIN(C,4), \
   PIN(C,5), \
   PIN(C,6), \
   PIN(C,7), \
   PIN(C,8), \
   PIN(C,9), \
   PIN(C,10), \
   PIN(C,11), \
   PIN(C,12), \
   PIN(C,13), \
   PIN(C,14), \
   PIN(C,15), \
   PIN(D,0), \
   PIN(D,1), \
   PIN(D,2), \
   PIN(D,3), \
   PIN(D,4), \
   PIN(D,5), \
   PIN(D,6), \
   PIN(D,7), \
   PIN(D,8), \
   PIN(D,9), \
   PIN(D,10), \
   PIN(D,11), \
   PIN(D,12), \
   PIN(D,13), \
   PIN(D,14), \
   PIN(D,15), \
   PIN(E,0), \
   PIN(E,1), \
   PIN(E,2), \
   PIN(E,3), \
   PIN(E,4), \
   PIN(E,5), \
   PIN(E,6), \
   PIN(E,7), \
   PIN(E,8), \
   PIN(E,9), \
   PIN(E,10), \
   PIN(E,11), \
   PIN(E,12), \
   PIN(E,13), \
   PIN(E,14), \
   PIN(E,15), \
   PIN(H,0), \
   PIN(H,1), \
There is no " it can't be done" :)
Re: STM32F765zg, can get even the simples usb test to work
Post by RogerClark » Tue Nov 21, 2017 2:14 am
I think you should also post to
viewforum.php?f=48
Spawn32
Post by Spawn32 » Tue Nov 21, 2017 2:57 am
Thanks, will do :)
Spawn32
Re: (Solved) STM32F765zg, can get even the simples usb test to work
Post by Spawn32 » Tue Nov 21, 2017 7:06 pm
Fixed..
You need to replace the usbd_conf_F7.h in STM32GENERIC with one from the latest st cube_mx.
in line 308 of the new file, exchange _Error_Handler(__FILE__, __LINE__); to Error_Handler();
So now i have usb, nice :)
