AccelStepper with F407
FiveO
Post by FiveO » Tue Jan 23, 2018 10:43 am
Hi
Today I wanted to try AccelStepper library with F407. Stepper is not moving! Do I need declare pins to PWM or what?
I am using PWM pins PE14(for steps) and PE15(for dir).
Simple code example:
#include <AccelStepper.h>
AccelStepper stepper(1,PE14,PE15); // driver, step, dir
   stepper.setMaxSpeed(2000);
  stepper.setSpeed(1000);
   stepper.runSpeed();
I am using voltage shifter for driver(5v), grounds connected. Code worked with Arduino Mega.
FiveO
Re: AccelStepper with F407
Post by FiveO » Wed Jan 24, 2018 9:41 am
I tried other pins(PB0,PB1), still not moving. Next I tried with STM32F103C8 and MapleMini F103CB on STM32GENERIC - working!
So why it is not working on F407VE?
BennehBoy
Post by BennehBoy » Wed Jan 24, 2018 10:22 am
It's a less mature core, incompatibilities should be expected.
Perhaps try SteveStrongs fork of Roger's core which has better F4 support?
https://github.com/BennehBoy
Post by stevestrong » Wed Jan 24, 2018 10:23 am
Which library do you use? A link to it would be useful.
Post by stevestrong » Wed Jan 24, 2018 12:34 pm
I think you should set the mode of those pins to output:
  pinMode(PE14, OUTPUT);
  pinMode(PE15, OUTPUT);
or
  stepper.enableOutputs();
FiveO
Post by FiveO » Wed Jan 24, 2018 1:27 pm
to BennehBoy: I will try it tomorrow.
to stevestrong:
First didn't change a thing.
Second solution - pins not declared in this scope. I tried this with stepper.enableOutputs(); :
int stepPin = PE14;
int dirPin = PE15;
AccelStepper stepper(1, stepPin, dirPin); // step, dir
Same story, pins not declared?
Post by stevestrong » Wed Jan 24, 2018 2:19 pm
You have used already the pins PE14,15 for the AccelStepper instance in your original code:
So how comes that for that you did not get the "pins not declared" error message?
FiveO
Post by FiveO » Wed Jan 24, 2018 3:06 pm
Sorry :D My mistake. I had chosen wrong board.
It compiles ok with first and second example, but stepper won't run.
Post by zmemw16 » Wed Jan 24, 2018 3:38 pm
how are you downloading to target ? if st-link or jtag, pretty sure the low bits of PB and a couple in PA get messed with.
use disableDebugPorts(); // in setup
use enableDebugPorts(); // in the code that terminates execution maybe on a button press ... ... ...
if its HAL you may need to check which mode debug is set to ? i use CubeMX and then in the sys device i select the debug mode, generate code & report to see the values and masks etc
usual questions btw
os, version, arduino version, which core, from where & when, download method & target is f407ve ?
