Fixed utoa() function definition
Post by RogerClark » Mon Jul 03, 2017 6:46 am
https://github.com/rogerclarkmelbourne/ ... 2/pull/271
Need to confirm if there is any impact from this. (probably its OK)
Re: Fixed utoa() function definition
Post by stevestrong » Mon Jul 03, 2017 12:22 pm
Worked fine for me.
Post by victor_pv » Mon Jul 03, 2017 2:27 pm
I haven't tested, but a search in the core to see if any other file used it only shows 2 matches. They both take an input as char and int and pass it to utoa, so changing the function from long to int should not affect them.
https://github.com/rogerclarkmelbourne/ ... String.cpp
Post by RogerClark » Mon Jul 03, 2017 10:36 pm
I'll merge this PR
Edit.
Looks like the merge needs to be done manually :-(
