Fix bug in serial communication during SPI debug
Post by RogerClark » Mon Jul 03, 2017 6:56 am
https://github.com/rogerclarkmelbourne/ ... 2/pull/246
Seems to make changes beyond its title
Also, I am not sure why there are print statements in the SPI class at all for debugging. IMHO, there is no need to have these, and they could be removed.
There is also an unassociated change for Nucleo serial port, and its not good practice to do unrelated changes within the same PR
Re: Fix bug in serial communication during SPI debug
Post by stevestrong » Mon Jul 03, 2017 9:44 am
Yes, the PRs should be separated.
I also opt for removing the DEBUG lines from SPI.
Post by victor_pv » Mon Jul 03, 2017 10:59 pm
I agree on separating it in 2 PRs, and agree on removing the debug print statements.
I think SPI is mature enough to not need much debugging unless we are adding something new to it.
I can't comment on whether the changes for the Nucleo are needed since it seems to number the Serial ports in a different order than the hardware numbering. Is that to match pin labels in the nucleo board?
