[--] USBSerial tx speed issue [SOLVED BY UPDATING TO THE LATEST VERSION OF THE REPO]
Pito
Re: [libmaple and Generic] USBSerial tx speed issue
Post by Pito » Sun Jul 16, 2017 7:49 am
This thread should be moved in other board, as I've written above - I put it here by my mistake.
I did not test any PR, I only complained on USB TX performance and applied your patch then manually..
My local libmaple repo is old.
Post by stevestrong » Sun Jul 16, 2017 8:24 am
Does this mean that this issue is not relevant for libmaple anymore?
In this case please remove libmaple from the title.
Pito
Re: [Generic] USBSerial tx speed issue
Post by Pito » Sun Jul 16, 2017 8:36 am
@steve: again, I do not test nor comment any PRs here, I do not know whether your latest PR re USBSerial TX speed issue works with the latest libmaple core, as I do not use the latest libmaple core..
RogerClark
Re: [--] USBSerial tx speed issue
Post by RogerClark » Sun Jul 16, 2017 10:25 am
OK.
So this has been fixed ages ago
Its because @Pito was using a fairly old version of the repo.
I guess this is something we should also everyone when the report a bug, i.e "Are you using the latest version of the repo"
PS. I changed the thread title to show this is solved
