PR to add optimisation menu (to all boards individually)
Re: PR to add optimisation menu (to all boards individually)
Post by fpiSTM » Tue Sep 19, 2017 4:22 am
victor_pv wrote:
Mon Sep 18, 2017 8:36 pm
I actually had hoped that you would say it's ok to use it :(
I tried to use the DWT CYCNT for F103 but I do not succeed to write properly the DWT CTRL register. I think it locked by default (probably because I used STLink) so it required to be unlocked.
I found this nice example and think I'm in this case:
https://github.com/PetteriAimonen/STM32 ... mple.c#L35
but I did not checked.
Post by fpiSTM » Tue Sep 19, 2017 2:40 pm
To conclude, by adding:
uint32_t __attribute__((optimize("Os"))) pulseIn( uint32_t pin, uint32_t state, uint32_t timeout )
This will avoid any issue and allow to keep hardcoded clock cycle to 16 even if opt is changed.
Post by RogerClark » Tue Sep 19, 2017 8:51 pm
Has this been tested with gcc 4.x ?
Post by fpiSTM » Wed Sep 20, 2017 8:19 am
I've tested on the BP with Arduino_STM32 repo.
without the fix, using O1 provide wrong value while with the fix it's ok.
of course with the 4.8.3 toolchain ;)
Post by RogerClark » Wed Sep 20, 2017 8:27 am
OK.
Thats interesting.
Post by fpiSTM » Thu Sep 21, 2017 12:49 pm
Welcome, I have also to thank you, I've added this PR to the Arduino_Core_STM32.
https://github.com/stm32duino/Arduino_C ... 2/pull/110
Very useful to avoid to edit platform.txt :)
Just one information for those using arm gcc 6-2017-q1-update to use LTO feature, it is required to use the arm gcc 6-2017-q2-update
previous one has a bug causing a segmentation fault during the build.
Post by RogerClark » Thu Sep 21, 2017 8:48 pm
No worries...
Re:LTO
I have not noticed any problems in gcc 4.x, except LTO does not always result in smaller or faster code.
Also, in LibMaple I have noticed enabling LTO shows some warnings during compilation, but they dont seem to effect the operation of the code.
Post by fpiSTM » Fri Sep 22, 2017 5:30 am
Yes in fact it's a regression of the v6. so v4.8 is not impacted.
