Should I2C use Hardware by default
RogerClark
Post by RogerClark » Mon Jul 31, 2017 3:59 am
In issue
https://github.com/rogerclarkmelbourne/ ... issues/301
The question of usage of Hardware vs Software I2C was raised
I'm not sure if we can perhaps change to Hardware I2C as the default, now that its working
feurig
Re: Should I2C use Hardware by default
Post by feurig » Mon Jul 31, 2017 5:40 am
+1
It seems ridiculous to bitbang i2c when there is reasonable hardware to support it and working software.
Just my 2 pfennigs ..
Post by stevestrong » Mon Jul 31, 2017 8:31 am
+1
I agree with @feurig.
RogerClark
Post by RogerClark » Mon Jul 31, 2017 9:46 am
I should have said, that I think its time to move to HardWire
So unless someone disagrees I think I'll have a go at changing to HardWire and test with a BME280 that I have in my box of spares.
victor_pv
Post by victor_pv » Mon Jul 31, 2017 12:51 pm
+1 on using it.
RogerClark
Post by RogerClark » Mon Jul 31, 2017 9:28 pm
OK.
Sounds like another "little" job for any spare time I can scrape together
PS. Changing the code is the easy bit.
It's testing that takes the time ;-)
RogerClark
Post by RogerClark » Tue Aug 01, 2017 6:58 am
OK.
I've changed this over in this commit
https://github.com/rogerclarkmelbourne/ ... 8eda8254e6
I've tested with a STM time of flight device (VL53L0X ) which is I2C and it worked fine, to read data from this device and also the I2C scanner works
I've renamed HardWire files to Wire, and the old bit banged files to SoftWire
I've also updated the examples so there is an example of Wire, SoftWire and HardWire (Hardwire is now the same as Wire)
