[Libmaple] pinMode() disables timer even if no PWM mode involved
LibMaple (The core that Roger's repo uses)
edogaldo
Re: pinMode() disables timer even if no PWM mode involved
Post by edogaldo » Thu May 18, 2017 4:39 pm
Just an idea: reinvoking pinMode() doesn't solve the issue?
rmdMoba
Post by rmdMoba » Thu May 18, 2017 8:34 pm
victor_pv wrote:I suspect the case may be that when SPI or Serial end, the pins are not configured completely back to default and something extra may need to be done.
I supposed this too, and changed the end method of SPI tentatively. I set all the control registers to '0' ( the reset state ), but it changed nothing.
edogaldo wrote:Just an idea: reinvoking pinMode() doesn't solve the issue?
That's the way how I tried to switch back to PWM: seting pinMode to PWM and then pwmWrite() - but it didn't work.
Post by RogerClark » Thu May 18, 2017 8:43 pm
can you post your test code
edogaldo
Post by edogaldo » Thu May 18, 2017 8:59 pm
By the way, I just noticed this thread is in "STM core: Bugs and enhancements" section.
If we are referring to the Maple core I'd suggest to move it elsewhere..
Too many cores these days... :? :lol:
rmdMoba
Post by rmdMoba » Thu May 18, 2017 9:01 pm
I checked the output on PA7 with a scope:
// Test PWM on maplemini  pin 4 / PA7 ( general Output / SPI and PWM )
#include <SPI.h>
const byte Led1P = 16; // Led active during PWM Output
const byte test1P = 4;  // = port A7 ( SPI1-MOSI or TIM3 Ch2 )
SPIClass mySPI(1);
  pinMode( Led1P, OUTPUT );
  digitalWrite( Led1P, HIGH );
  pinMode( test1P, INPUT_PULLUP );
  delay( 1000 );
  digitalWrite( Led1P, LOW );
  pinMode( test1P, PWM );           // This PWM Sequence works fine
  for ( byte i=0; i<220; i++ ) {
     //analogWrite( test1P, i );
     pwmWrite( test1P, i*257 );
     delay( 20 );
  delay( 1000 );
  pinMode( test1P, OUTPUT );        // General IO - works fine too
  for ( byte i=0; i<11; i++ ) {
    digitalWrite(test1P, i&1 );
    delay( 5 );
  pinMode( test1P, INPUT );
  mySPI.begin();                    // SPI output - works fine
  mySPI.beginTransaction(SPISettings(550000, MSBFIRST, SPI_MODE0, DATA_SIZE_16BIT));
    mySPI.write(0x5555);
    delay( 5 );
  mySPI.endTransaction();
  mySPI.end();
  pinMode( test1P, OUTPUT );        // general OUTPUT - it works
  digitalWrite( test1P, LOW );
  delay(500);
  digitalWrite( test1P, HIGH );
  pinMode( test1P, PWM );           // The following PWM sequence doesn't work
  for ( int i=220; i>0; i-- ) {     // pin test1P seems to be in high impedance
     //analogWrite( test1P, i );    // state
     delay( 20 );
  mySPI.begin();                    // This again works
  for ( int i=0; i<11; i++ ) {
    delay( 5 );
  mySPI.end();
/*  Serial1.begin( 1200 );
  delay( 1000);
  Serial1.println("start-dimming");
  delay(1000); */
Edit: I used the 'rogerclarkmelbourne/Arduino_STM32' repository from Github
Post by victor_pv » Thu May 18, 2017 9:27 pm
rmdMoba wrote:I checked the output on PA7 with a scope:
#include <SPI.h>
SPIClass mySPI(1);
  delay( 1000 );
     delay( 20 );
  delay( 1000 );
    delay( 5 );
    delay( 5 );
  mySPI.end();
  delay(500);
     delay( 20 );
    delay( 5 );
  mySPI.end();
  delay( 1000);
  delay(1000); */
Not sure if you already address that, but the SPI library disables the Timer device mapped to the pins it uses:
    disable_pwm(nssi);
    disable_pwm(scki);
    disable_pwm(misoi);
    disable_pwm(mosii);
So you will need to enable the timer device again.
rmdMoba
Post by rmdMoba » Fri May 19, 2017 7:14 am
victor_pv wrote:So you will need to enable the timer device again.
Yes, sure. But that is what
should do.
After a reset the timer is disabled too, and pinMode() sets it accordingly to create PWM pulses. Why does this not work when SPI disabled the timer?
Post by victor_pv » Fri May 19, 2017 4:04 pm
should do.
Not sure if pinMode really enables the Timer device, or just enables the channel output. If you have confirmed it in the code already then that's it, but if you haven't, confirm it to be sure.
EDIT:
I confirmed it, does not enable the timer device, only the channel.
rmdMoba
Post by rmdMoba » Fri May 19, 2017 9:21 pm
victor_pv wrote: I confirmed it, does not enable the timer device, only the channel.
That's true, but it's not the problem. Activating SPI also disables only the channel. The timer itself is still running. This is essential, because there are other channels where pwm may be active on non SPI pins.
The problem is obviously, that SPI blocks the PWM output even after an SPI.end().
If I remap the SPI output ( AFIO Register MAPR ) to the alternate pins after executing SPI.end(), then PWM works again.
// Test PWM on libmaple 4 ( general Output / SPI and PWM )
#include <SPI.h>
// const byte test1P = 7;  //Generic = port A7 ( SPI1-MOSI or TIM3 Ch2 )
const byte test1P = 4;  // MapleMini = port A7 ( SPI1-MOSI or TIM3 Ch2 )
SPIClass mySPI(1);
    delay( 1000 );
     delay( 20 );
    delay( 1000 );
    delay( 5 );
    mySPI.end();
    AFIO_BASE->MAPR = 1;            // remap SPI1
    pinMode( test1P, PWM );         // The following PWM sequence only works if SPI is remapped
     delay( 20 );
    AFIO_BASE->MAPR = 0;            // remap SPI1 back to standard pins
    delay( 5 );
    mySPI.end();
Post by victor_pv » Fri May 19, 2017 9:32 pm
#include <SPI.h>
SPIClass mySPI(1);
    delay( 1000 );
     delay( 20 );
    delay( 1000 );
    delay( 5 );
    mySPI.end();
     delay( 20 );
    delay( 5 );
    mySPI.end();
I am a bit confused by this sentence " If I remap the SPI output ( AFIO Register MAPR ) to the alternate pins after executing SPI.end(), then PWM works again.". Does that mean you were not using the default SPI pins, but alternate ones instead? or you were using the normal ones, then if you switch to the alternate ones for SPI1 then PWM works again?
