U8Glib I2C sh1106
Mabez
U8Glib I2C sh1106
Postby Mabez » Tue Nov 22, 2016 12:19 am
Hi all,
I have been working on getting my sh1106 I2C OLED working with the STM32F103C using U8Glib but with no success, I previously managed to get it working with a teensy a few months back and I figured it would be a simple fix to get it working with this.
Here is the code for my u8g hardware function:
#include "u8g_arm.h"
const uint16_t SLAVE_ADR = 0x3C;    // == 0x78
const uint16_t DATA_MODE = 0x40;    // i2c data command
const uint16_t COMMAND_MODE = 0x00; // i2c command command; 0x80 -- either seems to work
uint16_t CTRL_CMD = 0;
uint8_t u8g_com_hw_i2c_fn(u8g_t *u8g, uint8_t msg, uint8_t arg_val, void *arg_ptr)
  switch(msg)
    case U8G_COM_MSG_STOP:
      //STOP THE DEVICE
    break;
    case U8G_COM_MSG_INIT:
      Wire.begin();
    break;
    case U8G_COM_MSG_ADDRESS:
      //SWITCH FROM DATA TO COMMAND MODE (arg_val == 0) for command mode
        CTRL_CMD = (arg_val == 0) ? COMMAND_MODE : DATA_MODE;
    break;
    case U8G_COM_MSG_RESET:
      // there's no reset pin .. ~ U8G_I2C_OPT_NO_ACK
    break;
    case U8G_COM_MSG_WRITE_BYTE:
      //WRITE BYTE TO DEVICE
      Wire.beginTransmission(SLAVE_ADR);    // slave addr
      Wire.write(CTRL_CMD);                 // cmd
      Wire.write(arg_val);                  // data
      Wire.endTransmission();
    break;
    case U8G_COM_MSG_WRITE_SEQ:
    case U8G_COM_MSG_WRITE_SEQ_P:
    //WRITE A SEQUENCE OF BYTES TO THE DEVICE
    register uint8_t *ptr = static_cast<uint8_t *>(arg_ptr);
    Wire.write(ptr, arg_val);
    break;
  return 1;
and here is the simple sketch:
#include <u8g_arm.h>
u8g_t u8g;
  u8g_InitComFn(&u8g, &u8g_dev_sh1106_128x64_i2c, u8g_com_hw_i2c_fn);
  u8g_FirstPage(&u8g);
  do {
      u8g_DrawStr(&u8g,42,55,"Loading...");
  } while( u8g_NextPage(&u8g) );
All the code compiles, but the display does not show anything. The display has been tested with a arduino nano and works fine. Using the wire scanner examples the display is found at the address 0x3C.
I am really stumped, any help would be appreciated!
Cheers,
Mabez
Who is online
Users browsing this forum: Baidu [Spider] and 1 guest
