ILI9341_due_STM library complie warning
Nont
Post by Nont » Wed Nov 23, 2016 10:35 am
Hello everybody,
i have old maple r3 from original leaflab
i use arduino IDE 1.6.12 and SAM 1.6.9 with lasted STM32duino try to run example on ILI9341_due_STM and got warning like code below
look like it double declare on DMA function, how could i fix it. thank in advance
Build options changed, rebuilding all
In file included from C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM/ILI9341_due_gText.h:36:0,
                 from C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\examples\graphicstest\graphicstest.ino:22:
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM/ILI9341_due.h:485:20: warning: extra tokens at end of #ifdef directive [enabled by default]
 #ifdef __SAM3X8E__ |  __STM32F1__
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp: In member function 'uint8 SPIClass::dmaTransfer(uint8*, uint8*, uint16)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:396:2: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
  dma_setup_transfer(_currentSetting->spiDmaDev, _currentSetting->spiRxDmaChannel, &_currentSetting->spi_d->regs->DR, DMA_SIZE_8BITS,
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:397:82: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                      receiveBuf, DMA_SIZE_8BITS, (DMA_MINC_MODE | DMA_TRNS_CMPLT));// receive buffer DMA
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:405:2: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
  dma_setup_transfer(_currentSetting->spiDmaDev, _currentSetting->spiTxDmaChannel, &_currentSetting->spi_d->regs->DR, DMA_SIZE_8BITS,
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:406:84: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        transmitBuf, DMA_SIZE_8BITS, (DMA_FROM_MEM | DMA_TRNS_CMPLT));// Transmit FF repeatedly
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:409:5: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:410:101: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        transmitBuf, DMA_SIZE_8BITS, (DMA_MINC_MODE |  DMA_FROM_MEM | DMA_TRNS_CMPLT));// Transmit buffer DMA
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp: In member function 'uint8 SPIClass::dmaSend(uint8*, uint16, bool)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:457:5: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:458:58: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        transmitBuf, DMA_SIZE_8BITS, flags);// Transmit buffer DMA
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp: In member function 'uint8 SPIClass::dmaSend(uint16*, uint16, bool)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:486:5: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
     dma_setup_transfer(_currentSetting->spiDmaDev, _currentSetting->spiTxDmaChannel, &_currentSetting->spi_d->regs->DR, DMA_SIZE_16BITS,
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp:487:59: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        transmitBuf, DMA_SIZE_16BITS, flags);// Transmit buffer DMA
In file included from C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI9341_due.cpp:45:0:
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI9341_due.h:485:20: warning: extra tokens at end of #ifdef directive [enabled by default]
In file included from C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI9341_due_gText.cpp:31:0:
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp: In function 'void ILI_spiDmaRX(uint8_t*, uint16_t)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:302:3: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
   dma_setup_transfer(DMA1, DMA_CH2, &SPI1->regs->DR, DMA_SIZE_8BITS,
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:303:75: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                      dst, DMA_SIZE_8BITS, (DMA_MINC_MODE | DMA_TRNS_CMPLT));
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp: In function 'void ILI_spiDmaTX(uint8_t*, uint16_t)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:322:5: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
     dma_setup_transfer(DMA1, DMA_CH3, &SPI1->regs->DR, DMA_SIZE_8BITS,
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:323:76: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        src, DMA_SIZE_8BITS, (DMA_FROM_MEM | DMA_TRNS_CMPLT));
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:326:5: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\ILI9341_due_STM\ILI_SdSpiSAM3X.cpp:327:94: warning: 'void dma_setup_transfer(dma_dev*, dma_channel, volatile void*, dma_xfer_size, volatile void*, dma_xfer_size, uint32)' is deprecated (declared at C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include/series/dma.h:563) [-Wdeprecated-declarations]
                        src, DMA_SIZE_8BITS, (DMA_MINC_MODE  |  DMA_FROM_MEM | DMA_TRNS_CMPLT));
Sketch uses 40,268 bytes (37%) of program storage space. Maximum is 108,000 bytes.
Global variables use 4,800 bytes of dynamic memory.
Re: ILI9341_due_STM library complie warning
Post by stevestrong » Thu Dec 22, 2016 2:40 pm
Which sketch are you trying to compile?
This library was committed by @victorpv, but I think is not supported anymore in this repo, as it is replaced by "Adafruit_ILI9341_STM".
Alternatively, try a version from victor's repo directly.
Post by mrburnette » Thu Dec 22, 2016 10:08 pm
Try my test sketch which uses Victor's DMA routine. The library is "bound" into the sketch directory.
https://www.hackster.io/rayburne/mesmer ... 103-62169b
			                 OLD STM Port			non-DMA STM Port                STM DMA Port
ILI9341 Test!
Benchmark             Time (microseconds)		Time (microseconds)        Time (microseconds)
Screen fill              1,026,635			          716,291                    174,901
Text                        74,910				        46,087                     65,358
Lines                      702,724			          400,688                    692,868
Horiz/Vert Lines            84,359				        57,074                     23,342
Rectangles (outline)        54,489				        36,604                     16,625
Rectangles (filled)      2,132,392			        1,487,410                    371,832
Circles (filled)           344,984			          220,662                    181,100
Circles (outline)          306,326			          174,199                    302,904
Triangles (outline)        222,948			          127,154                    219,106
Triangles (filled)         715,597			          472,077                    243,512
Rounded rects (outline)    130,131			           78,591                     91,564
Rounded rects (filled)   2,331,405			        1,615,938                    488,708
Done!
Post by RogerClark » Thu Dec 22, 2016 10:41 pm
There are some old examples which no longer compile (after changes to SPI / DMA - ages ago)
I'll just delete them, as git will retain their history even if I delete from the current HEAD in the master branch
Post by mrburnette » Thu Dec 22, 2016 10:45 pm
RogerClark wrote:There are some old examples which no longer compile (after changes to SPI / DMA - ages ago)
I have not been overly affected by changes in core and STM hacked libs; but, I put libraries into sketch folders as a general rule.
Post by RogerClark » Thu Dec 22, 2016 10:52 pm
This isnt the first time that someone has tried to use the Due examples, only to find they don't compile or don't run.
Now that our version of the ILI9341 code is working, it just causes confusion for new users by having these old libs, which were only put into the repo as reference while Victor etc were developing our versions.
So.. I've removed the ILI9341_due_STM folder.
(Actually only a one or two of them didnt compile and that was mainly because of external dependancies, but I don't have time to individually test all of them to confirm they actually work and do what they say they do, I think its still better to remove them.
Post by victor_pv » Sat Dec 24, 2016 12:04 am
Nont wrote:Hello everybody,
Nont, as Roger explained that library was ported a long time ago, while we were working on using DMA transfers. After a while we added the SPI DMA functions in the core, but that library has not been updated, so the functions in it clash with the functions already in the core.
I agree the best is to remove that obsolete library from the core.
As a side note, the library was originally ported because of some extra text functions, i.e. use different fonts, sizes. If anyone actually needs it, should be easy to rework it for the latest core, but until then better remove it.
