Page 16 of 18
Re: Lib for ILI9486 - 3.5 inch 480x320 touch TFT for RPi
Posted: Sun Mar 05, 2017 6:38 pm
by zmemw16
http://www.waveshare.com/wiki/3.5inch_RPi_LCD_(A)
good news, bad news
good - not much, you can find the pinning details for the socket
bad - couldn't see / find a schematic - rather surprised, but given the following lines perhaps understandable
bad - some cloning of their products
bad - yours doesn't seem to match their picture
bad - doesn't seem to match the fakes
i suspect the easiest is to find a Raspberry Pi and if there's anything in the driver or boot messages.
stephen
Posted: Mon Mar 06, 2017 10:32 am
by david.prentice
The good news is that you have the WaveShare logo on your pcb. So it might be genuine.
You can always ask WaveShare for the schematic. Or simply work it out by yourself.
I do not own a RaspPi. I know nothing about them.
David.
Posted: Mon Mar 06, 2017 11:58 am
by fari
Thanks Steve, David and Stephen for your precious hints!
I will work through your hints. Hopefully one of them would work.
Posted: Tue Mar 07, 2017 4:56 pm
by fari
Thanks Steve, David and Stephen for your help!
Finally I have got it done! I have found out the right initialisation sequence. The SPI frequency is crucial. The display works only in the range between 12MHz and 32MHz only. Any frequency out of this range lead to white flashing on the screen!
Posted: Tue Mar 07, 2017 8:40 pm
by stevestrong
I think I have mentioned already the SPI clock limitation to 24MHz, but it is good that you also figured out.
Posted: Wed Mar 08, 2017 12:08 pm
by fari
Yes! You are right Steve! but I had several problems:
- The described pin out of the display on the site of the vender was wrong :x (I tried at this time to lower the frequency, but with the wrong wiring!!! :roll: ). This problem was fundamental
- The Init sequence had to be changed slightly ( I have got the right sequence of the init sequence of a raspberry pi, which was posted in the internet)
- The frequency e.g. 8MHz does not work. I could not understand till now, why lower frequencies did not work
After I have found out, that the pin out description was wrong, I managed to solve the problem very fast.
Thanks to all for the support!
If you might be interested, here is the right pin out of the display I am using (http://www.ebay.de/itm/252472008067?ul_noapp=true):
35Inch Display Pinout.jpg (163.87 KiB) Viewed 1131 times
Here is the best init sequence I had:
Command: 0xb0, Data: 0x0,
Command: 0x11,
DELAY 250ms
Command: 0x3A, Data: 0x55,
Command: 0xC2,Data: 0x44,
Command: 0xC5,Data: 0x00,0x00,0x00,0x00,
Command: 0xE0,Data: 0x0F,0x1F,0x1C,0x0C,0x0F,0x08,0x48,0x98,0x37,0x0A,0x13,0x04,0x11,0x0D,0x00,
Command: 0xE1,Data: 0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,
Command: 0xE2,Data: 0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,
Command: 0x36,Data: 0x48,
Command: 0x11,
DELAY 250 ms
Command: 0x29
The display works only in the range between 12MHz and 32MHz .
Good luck!
Posted: Fri May 19, 2017 3:49 pm
by stevestrong
Back again after a long time just to inform you about an update.
I modified my ILI9486 - SPI board for 16bit parallel access. The reason was to obtain higher write speed.
The files can be found here: https://github.com/stevstrong/Adafruit_ ... 6bit_STM32
I tested it with my black F4 board.
The current benchmark:
Benchmark                Time (microseconds)
Screen fill              104767
Text                     10386
Lines                    185635
Horiz/Vert Lines         9400
Rectangles (outline)     5971
Rectangles (filled)      255546
Circles (filled)         95452
Circles (outline)        78896
Triangles (outline)      51741
Triangles (filled)       112147
Rounded rects (outline)  26409
Rounded rects (filled)   295197
This shows a clear improvement in most of the cases compared to SPI access benchmark, but not that impressive for triangles (outline) test.
The critical point by parallel access is the minimum low time for the WR pulse, it must be at least 100ns. This is achieved using F4 with the normal digitalWrite() function. Any further speed optimization using register direct access leads to corrupted display in case of F4.
Maybe for F1 it would make sense, but I did not try it at the moment.
Posted: Fri May 19, 2017 4:47 pm
seem like the f4 is *too fast* for the lcd, the limit it seemed is not the number of parallel wires, it is how fast that mcu on the lcd can work :lol:
Posted: Sat May 20, 2017 3:09 pm
by stevestrong
Indeed, F4 is unbelievable fast!
Here the bench using FSMC:
Screen fill              48091
Text                     5683
Lines                    83850
Horiz/Vert Lines         4258
Rectangles (outline)     2655
Rectangles (filled)      117322
Circles (filled)         39360
Circles (outline)        35190
Triangles (outline)      23373
Triangles (filled)       50048
Rounded rects (outline)  12160
Rounded rects (filled)   134562
I think, this is incredibly good performance for a 320*480 display.
Posted: Sat May 20, 2017 3:35 pm
by magflip
stevestrong wrote:Back again after a long time just to inform you about an update.
Screen fill              104767
Text                     10386
Lines                    185635
I've been trying for a week to make my ILI9486 works with a Generic STM32F103C (blue pill) but unfortunately, I still have not been able to get it to work. Using this library, how can I wiring both (ILI9486 shield for uno and Blue pill)? I can't understand how can I do it.
