Lib for ILI9486 - 3.5 inch 480x320 touch TFT for RPi
Re: Lib for ILI9486 - 3.5 inch 480x320 touch TFT for RPi
Post by Pito » Sun Jan 08, 2017 10:19 am
I am going to overclock the ZET6 too, see above my post.
I did it 100x but in other environments. It is extremely easy with chibios or with original ST libs.
You just change the PLL multiplier from 9 to 12 in the setup in our case.
The sw setup is usually written such it adjusts all other settings. Not sure how it works here. Core guys must say.
I always let the flash settings (flash waitstates) as-is as the overclock to 96MHZ is small and the 103C will work with 96MHz fine.
Post by Pito » Sun Jan 08, 2017 10:27 am
@Pito, where can I find info how to overclock to 96MHz beside this?
As a dirty hack try in boards_setup.cpp for BP
// Allow boards to provide a PLL multiplier. This is useful for
// e.g. STM32F100 value line MCUs, which use slower multipliers.
// (We're leaving the default to RCC_PLLMUL_9 for now, since that
// works for F103 performance line MCUs, which is all that LeafLabs
// currently officially supports).
#ifndef BOARD_RCC_PLLMUL
#define BOARD_RCC_PLLMUL RCC_PLLMUL_12
Hopefully the setup sw is using the BOARD_RCC_PLLMUL for all other timing settings too.. :)
USB - shall work fine in 103 with integer multiplies of 48MHz.
PS: I did with my board but USB stops working.
So there must be the USB divider set to 2 manually too..
PPS: now I see why, thanks Roger :)
Post by RogerClark » Sun Jan 08, 2017 10:38 am
Take a look at the GD32F103 board and variant.
I added CPU speed to that variant as it will operate on a wider range of frequencies while still maintaining USB.
Unfortunately, the STM32F103 will only run at 72Mhz or 48Mhz and still run USB, as USB clock is run from the main clock (after its been multiplied up), and there only two divider values (1.5 and 1.0)
Post by Pito » Sun Jan 08, 2017 10:55 am
With my above hack the usb stops working as Roger indicates, with Serial1 it does not set the correct uart baudrate, but the code works it seems..
When I add the cpu freq
#define F_CPU 96000000
it does not help with the uart baudrate either - so it seems the timing settings in this environment are set by if-endif rather than by actual calculation from F_CPU.
The other envirs I saw they set PLL_MUL and XTAL_FREQ and from that they got F_CPU and then all other settings (usb, uarts, timers, systick, adc_samprates, etc.) are calculated within the setup from this single value.
So I think the board's variants shall include only F_XTAL and PLLMUL as the only parameters..
Or, better, F_CPU and the F_XTAL as the only parameters.. We have got computers for everything else to be calculated/derived :P
Post by Pito » Sun Jan 08, 2017 11:37 am
Adding the CPU Frequency speed setting into the Tools-> menu:
Add in ..\Arduino_STM32\STM32F1\boards.txt into your BPill board (103C) variant in the:
###################### Generic STM32F103C ########################################
#---------------------------- UPLOAD METHODS ---------------------------
<<<<<<<< HERE
this:
genericSTM32F103C.menu.cpu_speed.speed_72mhz=72Mhz (standard)
genericSTM32F103C.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103C.menu.cpu_speed.speed_48mhz=48Mhz (underclk)
genericSTM32F103C.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103C.menu.cpu_speed.speed_96mhz=96Mhz (overclk)
genericSTM32F103C.menu.cpu_speed.speed_96mhz.build.f_cpu=96000000L
genericSTM32F103C.menu.cpu_speed.speed_120mhz=120Mhz (superoverclk)
genericSTM32F103C.menu.cpu_speed.speed_120mhz.build.f_cpu=120000000L
genericSTM32F103C.menu.cpu_speed.speed_128mhz=128Mhz (ultraoverclk)
genericSTM32F103C.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
and use this hack in ..\Arduino_STM32\STM32F1\variants\generic_stm32f103c\wirish\boards_setup.cpp:
// works for F103 performance line MCUs, which is all that LeafLabs currently officially supports).
#if F_CPU==96000000
#elif F_CPU==72000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_9
#elif F_CPU==48000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_6
#elif F_CPU==120000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_15
#elif F_CPU==128000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_16
Here the serial1 starts working properly. It compiles with 96MHz. Double checked with Whetstone.
You must restart ide and you will see in the Tools->CPU Speed(MHz) the above speed settings selections with your board.
PS: the USB may not work with some speeds settings..
PPS: my 103ZET6 board:
Starting Whetstone benchmark...
Loops: 1000Iterations: 1Duration: 20366 millisec.
C Converted Double Precision Whetstones: 4.91 MIPS   <<< 72MHz
Loops: 1000Iterations: 1Duration: 15250 millisec.
C Converted Double Precision Whetstones: 6.56 MIPS   <<< 96MHz
Loops: 1000Iterations: 1Duration: 12201 millisec.
C Converted Double Precision Whetstones: 8.20 MIPS   <<< 120MHz
Loops: 1000Iterations: 1Duration: 11438 millisec.
C Converted Double Precision Whetstones: 8.74 MIPS  <<< 128MHz
Post by stevestrong » Sun Jan 08, 2017 12:27 pm
Thanks Pito, I managed to change the SPI clock to 24MHz (see my post here for how to).
And the display works fine at 24MHz !
And USB is working, too. CPU runs with 48MHz, but is as fast as with 72Mhz because I set FLASH wait state down to 1.
Post by Pito » Sun Jan 08, 2017 12:34 pm
Great Steve, you doublechecked my guide too :) :)
I run my 103ZET6 at 128Mhz :)
In past I ran F100 (DiscoveryVL) at 56MHz with 0ws. Standard is 24MHz.. Some benchmarks did show 56 is faster than the F103 at 72.
Post by stevestrong » Sun Jan 08, 2017 1:05 pm
Here the benchmark with SPI = 24MHz, CPU at 48MHz, flash wait states = 0 (!!) ;) ,
with DMA:
Benchmark                Time (microseconds)
Screen fill              497067
Text                     66080
Lines                    563363
Horiz/Vert Lines         58813
Rectangles (outline)     41143
Rectangles (filled)      502296
Circles (filled)         332981
Circles (outline)        441015
Triangles (outline)      129064
Triangles (filled)       490033
Rounded rects (outline)  154242
Rounded rects (filled)   1415779
and without DMA:
Screen fill              513134
Text                     46200
Lines                    479177
Horiz/Vert Lines         43779
Rectangles (outline)     25931
Rectangles (filled)      1252740
Circles (filled)         291770
Circles (outline)        389888
Triangles (outline)      96710
Triangles (filled)       467875
Rounded rects (outline)  125560
Rounded rects (filled)   1396953
Squonk42
Post by Squonk42 » Sun Jan 08, 2017 1:59 pm
stevestrong wrote:Here the benchmark with SPI = 24kHz, CPU at 48MHz, flash wait states = 0 (!!) ;)
Isn't it 24 MHz instead of 24 kHz?
Post by stevestrong » Sun Jan 08, 2017 2:05 pm
But of course, thank you, I have corrected.
