Arduino ide Couldn't find the DFU device: [1EAF:0003] for STM32F103C8
Posted: Sat Aug 20, 2022 7:52 am
by Saylus21
I'M USING Arduino STM32 by Roger Clark Melbourne on GitHub " CORE.
I'VE TRIED MANY THINGS TO UPLOAD THE PROGRAM VIA THE USB PORT, BUT NOTHING WORKS.
SO I TRYED UPLOADING MY SKETCH USING THIS METHOD,
I'm curious to know if programming my blue pill with A11(D-) to 3.3V with a 1K resistor and C14 to 3.3V with a 2.2K resistor is a good idea (IT WORKED for while then stop working).
Re: Arduino ide Couldn't find the DFU device: [1EAF:0003] for STM32F103C8
Posted: Sat Aug 20, 2022 8:53 am
welcome, if you are new, it is recommended to start with the 'official' STM core
this core supports (much) more boards and get something like a Nucleo board with more resources, check on the core repository
^ e.g. Nucleo F401RE or Nucleo F411RE in the list
or like
to start with.
if you insist on '3rd party' ones there are many too,
https://store.micropython.org/product/PYBv1.1
https://www.aliexpress.com/wholesale?ca ... =stm32f401
but that these are less recommended for 'beginners' because you may be on your own if you stumble and is not familiar with stm32 mcu platform.
libmaple ('roger's core') these days is considered 'for experts', and if you insist do review the wiki
and check other reading materials here
viewtopic.php?f=2&t=3
viewtopic.php?f=2&t=301
edit:
the technical reason for what you are seeing is because stm32f103c8 don't have a "DFU bootloader", check in the wiki.
as like discussed, Nucleo F401RE or Nucleo F411RE has more support and with the 'official' STM core
they are easier to flash, has more memory and flash and is less "distressing" for beginners.
Otherwise, get a board in the stm32f4xx series like those mentioned prior, those have the DFU bootloader built in *on chip*, all of them have it
if you get the Adafruit board like mentioned above, Adafruit made a nice tutorial about it:
https://learn.adafruit.com/adafruit-stm ... er-details
Posted: Sat Aug 20, 2022 10:26 am
by GonzoG
Have you flashed proper bootloader ??
