MicroSD card socket
MicroSD card socket
Postby Pito » Wed Jan 11, 2017 10:57 am
FYI - this socket works fine with SPI 36MHz. I got a bunch (I forgot the actual seller). On the pcb 4x 10k pullups and 2 decoupling caps. It works with MM here fine. Fits solderless breadboard pitch.
http://www.ebay.com/itm/2PCS-TF-Micro-S ... SwLnlWmKBY
racemaniac
Re: MicroSD card socket
Postby racemaniac » Wed Jan 11, 2017 12:33 pm
Pito wrote:FYI - this socket works fine with SPI 36MHz. I got a bunch (I forgot the actual seller). On the pcb 4x 10k pullups and 2 decoupling caps. It works with MM here fine. Fits solderless breadboard pitch.
i ordered the same from aliexpress, they're indeed very good for the maple mini :)
Postby Pito » Wed Jan 11, 2017 12:51 pm
I HIGLY RECOMMEND to solder the two pads the metal cover is fit to the pcb with a good blob of tin :)
Otherwise it works ok with MM, BP, BlueZEX.
Postby Pito » Wed Jan 11, 2017 1:28 pm
Could we find something similar for SDIO??
Manny
Postby Manny » Wed Jan 11, 2017 6:55 pm
X1 ...Yes very good for the price, I ordered 3 and received 6, it did take ages to arrive from a different vendor.
I've been plagued with reliability problems from using the SD card slot on the back of a generic 2.8" TFT screen and SDfat Beta, it's been rock solid using these, if I was being picky there's no noticeable click to hold the microSD card, you kind of jam it in there.
Who is online
