SDFat library - how to get work parseInt() ?
Re: SDFat library - how to get work parseInt() ?
Post by Pito » Sat Feb 18, 2017 1:01 pm
What does it mean "code does not work" ??
Do not try to mess with complex sketches, instead try to go step-by-step.
Try the original example (my above code snippet is from) from the SdFat until it works perfectly. And after then you may play with the code.
https://github.com/greiman/SdFat/blob/m ... rseInt.ino
Also mind the C language requires some rules are followed. The file1 must be declared global, otherwise it will not be visible inside a function.
See my snippet above.
Post by victor_pv » Sat Feb 18, 2017 1:48 pm
stm32_discoverer wrote:But I don't see
#define ARDUINO_FILE_USES_STREAM 1
in "SdFatConfig.h"
You said you had seen the link, tried it and didn't work, but then say you dont see that. Well that's exactly what was referred to in the link, so what had you tried from the link that did not work?
Also, why are you using the beta instead of the stable version?
