Arduino Menu 3.0
Re: Arduino Menu 3.0
Post by victor_pv » Thu Mar 02, 2017 6:35 pm
BennehBoy wrote:
zmemw16 wrote:what happens when just printing item? 'Serial << item<<endl;'
Crashes
zmemw16 wrote:and add a simple 'Serial<<'***************'<<endl;' line to see if it dies there
srp
Prints out the asterisks, no crash.
I would say item is null. Is it a pointer to a string? if so, can you print the pointer value at that point?
This would be good use for a debugger ;)
BennehBoy
Post by BennehBoy » Thu Mar 02, 2017 7:06 pm
No it's a pointer to a class instance, I think basically it's self referential, the instance of the menu class that is selected passes a pointer to itself to the function, so that the code can say 'menu item x' was selected.
It's not important really because I don't think I'll ever need to use that within my menu system.
And yes a debugger would be good - sure the hell beats moving a 'Serial.println("got here");' about in the code :D
https://github.com/BennehBoy
BennehBoy
Post by BennehBoy » Thu Mar 02, 2017 9:11 pm
So it looks like idiot here must've done something daft, the code when refreshed from github runs fine on a nano, but still crashes the mini.
Post by RogerClark » Thu Mar 02, 2017 11:08 pm
Do you mean it crashes on some AVR boards ?
BennehBoy
Post by BennehBoy » Fri Mar 03, 2017 10:41 am
RogerClark wrote:Do you mean it crashes on some AVR boards ?
No it runs fine on AVR, I must've made some change when I was experiencing the garbage output - it did not crash however.
It _does_ crash on STM32 but only if that particular class is used - I've been in discussion with the author and his view was that that class was only used for demo purposes anyway. So, I'm going to go ahead and try to use it and see where I get.
Roger, I've had to change the build options to include gnu++11 in order to compile the code:
mapleMini.build.cpu_flags=-DMCU_STM32F103CB -DSERIAL_USB -std=gnu++11
So far I've not found any problems from doing so (other than cc1.exe warning about that option not being relevant).
Post by RogerClark » Fri Mar 03, 2017 11:20 am
These flags have been discussed on another thread
http://www.stm32duino.com/viewtopic.php?t=1241
It sounds like they are now the standard for the ARM Arduino build settings, so we should consider using them.
However I can only do limited testing e.g. with my projects, so the proof of the pudding would be just to update the repo and wait for people to complain if it caused side effects
BennehBoy
Post by BennehBoy » Fri Mar 03, 2017 1:02 pm
RogerClark wrote:These flags have been discussed on another thread
Yeah and to be honest I don't think the burden of testing should fall on one person.
Perhaps we need a number of branches...
master (stable)
testing (first place that dev gets merged into once it appears stable)
dev (expect stuff to be broken)
Those of us on the 'bleeding' edge would then act as the canaries on 'testing' branch.
PS, forgive me if this stuff is already there! Maybe you need to pick some trusted folks (ie NOT me :D ) to delegate some of the admin/legwork to?
Post by victor_pv » Fri Mar 03, 2017 4:57 pm
Roger, I would recommend to open a post for the change and ask for people to test it.
I was in fact almost going to use the c11 flag the other day, but decided not to because if something worked for me with that may not work later with the normal repo, so I for one am happy to test it with a few things.
I'm using sdfat, an spi disaply, and the TMRpcm library I half finished to test the modifications to the SPI library, so I am using a few peripherals (spi1 and 2, DMA, Hardware Timers, Hardware Serial). If a few people joins using some more peripherals, we should be covered.
BennehBoy
Post by BennehBoy » Fri Mar 03, 2017 7:44 pm
My project uses H/W SPI & i2C, and a lot of libraries :D So has another base covered from the i2c perspective.
Post by RogerClark » Fri Mar 03, 2017 8:23 pm
Victor
Ok.
I will do that.
I will post a replacement platform.txt
