m trying to get an stm32l452re running but when i try to run my program, it fails at line 165 in stm32l4xx_hal_crc.c:
/* makes sure the input data format (bytes, halfwords or words stream)
* is properly specified by user */
assert_param(IS_CRC_INPUTDATA_FORMAT(hcrc->InputDataFormat));
When called from line 70 in "hw_config.c":
/* Initialize the CRC */
#if defined(HAL_CRC_MODULE_ENABLED)
HAL_CRC_Init(&hcrc);
- devenv_oFcP1WJmtm.png (18.73 KiB) Viewed 703 times
I'
How do i set it up so that hcrc is setup properly? Thanks!
by fpiSTM » Fri Feb 03, 2023 2:08 pm
I guess, You got this issue because you enabled the ASSERT.
As the handle hcrc does not init explicitly this field it is set to 0 which is not a correct value.
I've made a PR:
https://github.com/stm32duino/Arduino_C ... /pull/1941
