Hints about the MMC/SD card library by Roland Riegel
STM32
Re: Hints about the MMC/SD card library by Roland Riegel
Post by STM32 » Thu Apr 20, 2017 8:50 pm
Hi Stevestrong,
Thanks.
stevestrong wrote:
Try a simple blinky sketch with simple serial output in loop, without including SD card header.
I did it using Test_RTClock without problem.
stevestrong wrote:
Check the 3.3V voltage level, the on-board regulator is week.
I used an MSO oscilloscope and all seems to be fine.
stevestrong wrote:
It must be your software, and we cannot help if you don´t post it.
My software isn't mine, simply it's the SdInfo example provided with SdFat version 20160719.
Here it is:
 * This program attempts to initialize an SD card and analyze its structure.
#include <SPI.h>
#include "SdFat.h"
 * SD chip select pin.  Common values are:
 * Arduino Ethernet shield, pin 4.
 * SparkFun SD shield, pin 8.
 * Adafruit SD shields and modules, pin 10.
 * Default SD chip select is the SPI SS pin.
const uint8_t SD_CHIP_SELECT = PA4;
 * Set DISABLE_CHIP_SELECT to disable a second SPI device.
 * For example, with the Ethernet shield, set DISABLE_CHIP_SELECT
 * to 10 to disable the Ethernet controller.
const int8_t DISABLE_CHIP_SELECT = -1;
SdFat sd;
// serial output steam
ArduinoOutStream cout(Serial);
// global for card size
uint32_t cardSize;
// global for card erase size
uint32_t eraseSize;
// store error strings in flash
#define sdErrorMsg(msg) sdErrorMsg_F(F(msg));
void sdErrorMsg_F(const __FlashStringHelper* str) {
  cout << str << endl;
  if (sd.card()->errorCode()) {
    cout << F("SD errorCode: ");
    cout << hex << int(sd.card()->errorCode()) << endl;
    cout << F("SD errorData: ");
    cout << int(sd.card()->errorData()) << dec << endl;
uint8_t cidDmp() {
  cid_t cid;
  if (!sd.card()->readCID(&cid)) {
    sdErrorMsg("readCID failed");
    return false;
  cout << F("\nManufacturer ID: ");
  cout << hex << int(cid.mid) << dec << endl;
  cout << F("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
  cout << F("Product: ");
  for (uint8_t i = 0; i < 5; i++) {
    cout << cid.pnm[i];
  cout << F("\nVersion: ");
  cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl;
  cout << F("Serial number: ") << hex << cid.psn << dec << endl;
  cout << F("Manufacturing date: ");
  cout << int(cid.mdt_month) << '/';
  cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl;
  cout << endl;
  return true;
uint8_t csdDmp() {
  csd_t csd;
  uint8_t eraseSingleBlock;
  if (!sd.card()->readCSD(&csd)) {
    sdErrorMsg("readCSD failed");
    return false;
  if (csd.v1.csd_ver == 0) {
    eraseSingleBlock = csd.v1.erase_blk_en;
    eraseSize = (csd.v1.sector_size_high << 1) | csd.v1.sector_size_low;
  } else if (csd.v2.csd_ver == 1) {
    eraseSingleBlock = csd.v2.erase_blk_en;
    eraseSize = (csd.v2.sector_size_high << 1) | csd.v2.sector_size_low;
  } else {
    cout << F("csd version error\n");
    return false;
  eraseSize++;
  cout << F("cardSize: ") << 0.000512*cardSize;
  cout << F(" MB (MB = 1,000,000 bytes)\n");
  cout << F("flashEraseSize: ") << int(eraseSize) << F(" blocks\n");
  cout << F("eraseSingleBlock: ");
  if (eraseSingleBlock) {
    cout << F("true\n");
  } else {
    cout << F("false\n");
  return true;
// print partition table
uint8_t partDmp() {
  cache_t *p = sd.vol()->cacheClear();
  if (!p) {
    sdErrorMsg("cacheClear failed");
    return false;
  if (!sd.card()->readBlock(0, p->data)) {
    sdErrorMsg("read MBR failed");
    return false;
  for (uint8_t ip = 1; ip < 5; ip++) {
    part_t *pt = &p->mbr.part[ip - 1];
    if ((pt->boot & 0X7F) != 0 || pt->firstSector > cardSize) {
      cout << F("\nNo MBR. Assuming Super Floppy format.\n");
      return true;
  cout << F("\nSD Partition Table\n");
  cout << F("part,boot,type,start,length\n");
    cout << int(ip) << ',' << hex << int(pt->boot) << ',' << int(pt->type);
    cout << dec << ',' << pt->firstSector <<',' << pt->totalSectors << endl;
  return true;
void volDmp() {
  cout << F("\nVolume is FAT") << int(sd.vol()->fatType()) << endl;
  cout << F("blocksPerCluster: ") << int(sd.vol()->blocksPerCluster()) << endl;
  cout << F("clusterCount: ") << sd.vol()->clusterCount() << endl;
  cout << F("freeClusters: ");
  uint32_t volFree = sd.vol()->freeClusterCount();
  cout <<  volFree << endl;
  float fs = 0.000512*volFree*sd.vol()->blocksPerCluster();
  cout << F("freeSpace: ") << fs << F(" MB (MB = 1,000,000 bytes)\n");
  cout << F("fatStartBlock: ") << sd.vol()->fatStartBlock() << endl;
  cout << F("fatCount: ") << int(sd.vol()->fatCount()) << endl;
  cout << F("blocksPerFat: ") << sd.vol()->blocksPerFat() << endl;
  cout << F("rootDirStart: ") << sd.vol()->rootDirStart() << endl;
  cout << F("dataStartBlock: ") << sd.vol()->dataStartBlock() << endl;
  if (sd.vol()->dataStartBlock() % eraseSize) {
    cout << F("Data area is not aligned on flash erase boundaries!\n");
    cout << F("Download and use formatter from www.sdcard.org!\n");
  // Wait for USB Serial
  while (!Serial) {
    SysCall::yield();
  // use uppercase in hex and use 0X base prefix
  cout << uppercase << showbase << endl;
  // F stores strings in flash to save RAM
  cout << F("SdFat version: ") << SD_FAT_VERSION << endl;
  if (DISABLE_CHIP_SELECT < 0) {
    cout << F(
           "\nAssuming the SD is the only SPI device.\n"
           "Edit DISABLE_CHIP_SELECT to disable another device.\n");
  } else {
    cout << F("\nDisabling SPI device on pin ");
    cout << int(DISABLE_CHIP_SELECT) << endl;
    pinMode(DISABLE_CHIP_SELECT, OUTPUT);
    digitalWrite(DISABLE_CHIP_SELECT, HIGH);
  cout << F("\nAssuming the SD chip select pin is: ") <<int(SD_CHIP_SELECT);
  cout << F("\nEdit SD_CHIP_SELECT to change the SD chip select pin.\n");
  // Read any existing Serial data.
  do {
    delay(10);
  } while (Serial.available() && Serial.read() >= 0);
  cout << F("\ntype any character to start\n");
  while (!Serial.available()) {
    SysCall::yield();
  uint32_t t = millis();
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!sd.cardBegin(SD_CHIP_SELECT, SPI_HALF_SPEED)) {
    sdErrorMsg("\ncardBegin failed");
    return;
  t = millis() - t;
  cardSize = sd.card()->cardSize();
  if (cardSize == 0) {
    sdErrorMsg("cardSize failed");
    return;
  cout << F("\ninit time: ") << t << " ms" << endl;
  cout << F("\nCard type: ");
  switch (sd.card()->type()) {
  case SD_CARD_TYPE_SD1:
    cout << F("SD1\n");
    break;
  case SD_CARD_TYPE_SD2:
    cout << F("SD2\n");
    break;
  case SD_CARD_TYPE_SDHC:
    if (cardSize < 70000000) {
      cout << F("SDHC\n");
    } else {
      cout << F("SDXC\n");
    break;
  default:
    cout << F("Unknown\n");
  if (!cidDmp()) {
    return;
  if (!csdDmp()) {
    return;
  uint32_t ocr;
  if (!sd.card()->readOCR(&ocr)) {
    sdErrorMsg("\nreadOCR failed");
    return;
  cout << F("OCR: ") << hex << ocr << dec << endl;
  if (!partDmp()) {
    return;
  if (!sd.fsBegin()) {
    sdErrorMsg("\nFile System initialization failed.\n");
    return;
  volDmp();
Thanks.
STM32
Post by victor_pv » Thu Apr 20, 2017 9:30 pm
STM32 wrote:Hi Stevestrong,
Thanks.
Here it is:
#include <SPI.h>
#include "SdFat.h"
SdFat sd;
uint32_t cardSize;
uint32_t eraseSize;
uint8_t cidDmp() {
  cid_t cid;
    return false;
    cout << cid.pnm[i];
  cout << endl;
  return true;
uint8_t csdDmp() {
  csd_t csd;
    return false;
  } else {
    return false;
  eraseSize++;
  } else {
  return true;
uint8_t partDmp() {
  if (!p) {
    return false;
    return false;
      return true;
  return true;
void volDmp() {
  while (!Serial) {
    SysCall::yield();
    cout << F(
  } else {
  do {
    delay(10);
    SysCall::yield();
    return;
  t = millis() - t;
    return;
    cout << F("SD1\n");
    break;
    cout << F("SD2\n");
    break;
    } else {
    break;
  default:
  if (!cidDmp()) {
    return;
  if (!csdDmp()) {
    return;
  uint32_t ocr;
    return;
  if (!partDmp()) {
    return;
    return;
  volDmp();
Thanks.
STM32
Try some other of the sdfat examples just to confirm, but the examples have been used extensively so they should be ok.
Some SD card do not work as good in the spi mode, you may want to try different cards and different speeds.
I did the initial port of the sdfat library for our core, and the sdcard I was using first gave me many headaches. It worked only some times, so I spent countless hours checking the code thinking something should be bad, then checking connections, then it would work a few times, but next would fail with no changes. Eventually I decided to try a faster better sdcard (sandisk extreme), and everything worked perfect every run, over and over.
Post by stevestrong » Fri Apr 21, 2017 7:36 am
I would like to know which upload method do you use.
SD card with SdFat lib combined with USB serial is widely used by many users here in forum, including me. And it works.
But...
USB serial is only working if you use the "Smt32duino bootloader", or you add the linker flag "-DSERIAL_USB" to the build process.
The other thing is that the USB serial is visible on Win10 machine only 5 seconds after the board has been reset, this is the time needed to re-enumerate the COM ports.
So it can be that the SW runs OK, but you don't see anything because all the output data is already sent before you re-open the serial monitor after upload (and board reset).
OTOH, the line
while (!Serial);
is currently not working as expected for STM32, there is a PR regarding a change which would solve this issue.
That is why I would suggest to add a delay(6000); before outputting anything to serial.
And pay attention to all warning messages you get at build time.
STM32
Post by STM32 » Fri Apr 21, 2017 8:11 pm
Hi Stevestrong,
Thanks.
What you have written is conceptually correct, but in my opinion in this case it isn't SD card, nor SPI speed, nor connections, it can be only the code that is running on the "Blue Pill".
Anyone can test by himself without any need to have card, SD card connector nor wires connected to the "Blue Pill".
Simply load into "Blue Pill" the sketch I put in my previous post and start the terminal using the "Blue Pill" alone only connected to the computer via USB connector and no SD card nor reader connected.
In that case you should get this message on the terminal:
SdFat version: 20160719
Assuming the SD chip select pin is: PA4
Even by blindly hit the keyboard nothing happens, the terminal remains empty when instead this message should appear:
cardBegin failed
SD errorCode: 0X1
SD errorData: 0X0
With my two "Blue Pill" I can't get the messages, not even by pushing the reset button on the board.
That is the point.
The sample sketch named "Test_RTClock" is fully working just as well many other.
With a MSO oscilloscope I saw that code is running fine also if nothing appears into the terminal.
Both the "Blue Pill" I own they have a 1.5kohm pullup resistor on D+ (R10 on the board).
Based on all that I guess it is something in the SdInfo code.
I use "Blue Pill" board as normal Arduino board by using the on board microUSB while keeping "Boot0" and "Boot1" pins always connected to GND.
But...
Being an hardware guy I don't fully understand what do you mean, anyway on my two "Blue Pill" I have the Roger Clark's Smt32duino bootloader.
Maybe, but with different sketches the output into the terminal does work perhaps because better timing.
stevestrong wrote:
while (!Serial);
Ok,I'll dig the matter for what I'm able to understand it.
These are all the messages I get:
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0 Upload to Flash 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=480
error resetting after download: usb_reset: could not reset device, win error: The specified file could not be found.
Done!
The only problem is for the USB reset but it is always the same for all the sketches I have used until now, doesn't matter what they are.
Thanks.
STM32
Post by stevestrong » Sat Apr 22, 2017 7:28 am
The "Test_RTClock" example does not use the USB serial so you cannot compare with other sketches which use it.
The "Test_RTClock" example uses the USB serial in the main loop, so even if the first samples (within 5 seconds) are not shown, the rest is going to be shown in the serial monitor.
STM32 wrote:Being an hardware guy I don't fully understand what do you mean, anyway on my two "Blue Pill" I have the Roger Clark's Smt32duino bootloader.
It is not enough to have it on chip, you also have to use it.
The upload method you choose from Arduino IDE:
To check all warning messages you turn on verbose messages:
Arduino IDE: File -> Preferences: Show verbose output during: compilation - check the box.
Just insert the delay(6000) before outputting any serial messages as I suggested, try it and post here the result.
  while (!Serial) {
    SysCall::yield();
  delay(6000); // ***************************  insert this   !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You can send data in Arduino serial monitor.
STM32
Post by STM32 » Sat Apr 29, 2017 4:21 pm
Hi Stevestrong,
sorry for the late answer.
Thanks, your hint does works!
First it's nice to know that the "Test_RTClock" is different from other examples due it does use the USB serial in the main loop, thanks!
Then I have to point out that I misunderstood the "Smt32duino bootloader" thing.
I used it from the beginning and of course with "Smt32duino bootloader" as a upload method, so on my side the whole things were right already from the beginning.
Same as above, I already know how to check all warning messages by turning on verbose messages in
I repeat that finally using "delay(6000)" as you wrote just before outputting any serial messages does the trick, many thanks!
#include <SPI.h>
#include "SdFat.h"
SdFat sd;
uint32_t cardSize;
uint32_t eraseSize;
uint8_t cidDmp() {
  cid_t cid;
    return false;
    cout << cid.pnm[i];
  cout << endl;
  return true;
uint8_t csdDmp() {
  csd_t csd;
    return false;
  } else {
    return false;
  eraseSize++;
  } else {
  return true;
uint8_t partDmp() {
  if (!p) {
    return false;
    return false;
      return true;
  return true;
void volDmp() {
  while (!Serial) {
    SysCall::yield();
  delay(6000);
    cout << F(
  } else {
  do {
    delay(10);
    SysCall::yield();
    return;
  t = millis() - t;
    return;
    cout << F("SD1\n");
    break;
    cout << F("SD2\n");
    break;
    } else {
    break;
  default:
  if (!cidDmp()) {
    return;
  if (!csdDmp()) {
    return;
  uint32_t ocr;
    return;
  if (!partDmp()) {
    return;
    return;
  volDmp();
Here you go the output as shown into the serial terminal:
Assuming the SD chip select pin is: 4
init time: 666 ms
Card type: SD2
Manufacturer ID: 0X1B
OEM ID: SM
Product: 00000
Version: 1.0
Serial number: 0X6A40FA0A
Manufacturing date: 1/2013
cardSize: 1966.08 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: 0X80FF8000
Volume is FAT16
blocksPerCluster: 64
clusterCount: 59992
freeClusters: 59989
freeSpace: 1965.72 MB (MB = 1,000,000 bytes)
fatStartBlock: 2
fatCount: 2
blocksPerFat: 235
rootDirStart: 472
dataStartBlock: 504
Download and use formatter from http://www.sdcard.org!
Thank you so much Stevestrong!, for me now it's time to try to unlock the MMC side!
See you later.
STM32
