library for 16x2
dev
library for 16x2
Post by dev » Tue Apr 18, 2017 1:52 am
Do we have library for 16x2 lcd.
I searched the forum, but i found i2c based library. But i am using directly to port.
Nutsy
Re: library for 16x2
Post by Nutsy » Tue Apr 18, 2017 1:00 pm
Yep Liquid Crystal and Liquid Crystal i2c depending on your display interface...
I dont think you need a specualy ported version, just works out the box i think...
dev
Post by dev » Fri Apr 21, 2017 2:54 am
Thanks,
This is how i wrote code, As per library. Is this code correct?
#include <LiquidCrystal.h>
LiquidCrystal lcd(PB12,PB13,PA0,PA1,PA2,PA3);
  lcd.begin(16,2,1);
    // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
Now preparing for hardware.
salwan
Post by salwan » Sun Sep 10, 2017 1:25 pm
hi dev
did you get the answer of 2x16 lcd ? if yes can you help me i also have problem in same issue
csnol
Post by csnol » Tue Sep 12, 2017 9:41 pm
Use
  lcd.begin(16,2);
