nucleo-H743zi2 LTDC_IRQHandler()
MasterT
Post by MasterT »
I make LTDC running on nucleo-H7, adapted one of the oficial examples for H743-eval.
What I can't understand, is why LTDC_IRQHandler never called.
Steps I done:
 (example copy /paste:
  // Set LTDC Interrupt to the lowest priority
  HAL_NVIC_SetPriority(LTDC_IRQn, 0xF, 0);
  HAL_NVIC_EnableIRQ(LTDC_IRQn);
than:
#ifdef __cplusplus
    extern "C" {
  void LTDC_ER_IRQHandler(void);
  void LTDC_IRQHandler(void);
  void HAL_LTDC_ErrorCallback(LTDC_HandleTypeDef *hltdc);
  void HAL_LTDC_LineEventCallback(LTDC_HandleTypeDef *hltdc);
  void HAL_LTDC_ReloadEventCallback(LTDC_HandleTypeDef *hltdc);
/*#if (USE_HAL_LTDC_REGISTER_CALLBACKS == 1)
HAL_StatusTypeDef HAL_LTDC_RegisterCallback(LTDC_HandleTypeDef *hltdc, HAL_LTDC_CallbackIDTypeDef CallbackID,
                                            pLTDC_CallbackTypeDef pCallback);
#ifdef __cplusplus
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_0, GPIO_PIN_SET);
    HAL_LTDC_IRQHandler(&LtdcHandle);
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_0, GPIO_PIN_RESET);
  ReloadFlag = 1;
same trics works for void DMA1_Stream2_IRQHandler(void);
just importing as "extern" IRQHandler. But with LTDC I'm running out of ideas, testing with a scope GPIO I see that LTDC_IRQHandler never triggered, same time I know that two bits IE in interrupt register of the LTDC are set and if I push a button (example : LTDC_ColorKeying) everything just hangs up.
I also try to change:
#define USE_HAL_LTDC_REGISTER_CALLBACKS 1U /* LTDC register callback
0 to 1 and back, compiled code size is changed but no defference with LTDC_IRQHandler
.word LTDC_IRQHandler /* LTDC */
is in startup_stm32h743xx.s, so I don't know if it referenced somewhere - directory is "templates"
Re: nucleo-H743zi2 LTDC_IRQHandler()
You have to add extern "C" before each definition or extend your group.
MasterT
Post by MasterT »
Extern C already there, wrap in ifdef tags. I don't understand "extend group". LTDC_IRQHandler must be referenced somewhere, it's not part of the HAL .
See above. You have to add
extern "C" before each definition. I told group about the #ifdef.
extern "C" void LTDC_IRQHandler(void)
extern "C" void HAL_LTDC_ReloadEventCallback(LTDC_HandleTypeDef *hltdc)
  ReloadFlag = 1;
Weak handlers are defined in the startup file, IIWR
MasterT
Post by MasterT »
Thanks for reply.
Meanwhile I was diging into example code, and connted out this two line:
//      while(ReloadFlag == 0) {
It helps me differentiate if uCPU hang up really because of interrupt misconfiguration (seen this millions time with any peripheral)
or while{} stucks for another reason. I trace down bit setting in the (LTDC_SRCR) - bit:2 vertical blanking reload interrupt and (LTDC_IER) - bit:3 RRIE: Register reload interrupt enable. I see that pressing button indeed sets all chain in correct phase, but to my surprise SRCR bit newer resets as vertical blanking never happened. It must. So I rolled back default screen configuration ( my new version is highly optimized to 150 MHz , no porches before-after screen acive area and size was shrink down to 16x64).
And miracle comes, interrupt fired as it should.
So hardware issue, I 'd call it a bug - since blocking bits /interrupt flow because of wrong settings is an illegal action.
