Use STM32F103C8 with TFT 320QVT 9341
empirejrz
Post by empirejrz » Tue Jun 27, 2017 6:40 am
Good day everyone. I am beginner. I want to use STM32F103C8. Please introduce about How to connect STM32F103C8 with TFT 320QVT 9341 and library for use it?
empirejrz
Re: Use STM32F103C8 with TFT 320QVT 9341
Post by empirejrz » Tue Jun 27, 2017 6:45 am
My connection is
PA0 = DB8
PA1 = DB9
PA2 = DB10
PA3 = DB11
PA4 = DB12
PA5 = DB13
PA6 = DB14
PA7 = DB15
RS = PB6
WR = PB5
RD = PB4
CS = PB7
RST = PB8
Post by stevestrong » Tue Jun 27, 2017 6:53 am
I cannot see the images.
i assume it is 8 bit parallel TFT.
Just search the forum for "ili9341 8bit".
empirejrz
Post by empirejrz » Tue Jun 27, 2017 7:31 am
I download library Adafruit_TFTLCD_8bit_STM32-master and change Adafruit_TFTLCD_8bit_STM32.h
#define TFT_DATA_PORT GPIOA
// Port data bits D0..D7:
// enable only one from below lines corresponding to your HW setup:
#define TFT_DATA_LOW_NIBBLE 1 // take the lower 8 bits: 0..7
//#define TFT_DATA_HIGH_NIBBLE 1 // take the higher 8 bits: 8..15
//Control pins |RD |WR |RS |CS |RST|
#define TFT_CNTRL_PORT GPIOB
#define TFT_RD PB4
#define TFT_WR PB5
#define TFT_RS PB6
#define TFT_CS PB7
#define TFT_RST PB8 //PB0
#define TFT_RD_MASK BIT0 // digitalPinToBitMask(TFT_RD) //
#define TFT_WR_MASK BIT1 // digitalPinToBitMask(TFT_WR) //
#define TFT_RS_MASK BIT2 // digitalPinToBitMask(TFT_RS) //
#define TFT_CS_MASK BIT3 // digitalPinToBitMask(TFT_CS) //
So my LCD not show anything but It has information to serial port.
Post by stevestrong » Tue Jun 27, 2017 12:11 pm
The "TFT_.._MASK" is the bit number of the IO port.
So if you define
#define TFT_RD PB4 // port B bit 4
then you should have
#define TFT_RD_MASK BIT4 // bit 4
Can you post a link where did you buy the display?
empirejrz
Post by empirejrz » Wed Jun 28, 2017 1:09 am
empirejrz
Post by empirejrz » Wed Jun 28, 2017 1:29 am
I can do it. Thank you very much. I take your advice.
I change
#define TFT_RD			PB4
#define TFT_WR			PB5
#define TFT_RS			PB6
#define TFT_CS			PB7
#define TFT_RD_MASK		BIT4 // digitalPinToBitMask(TFT_RD) //
#define TFT_WR_MASK		BIT5 // digitalPinToBitMask(TFT_WR) //
#define TFT_RS_MASK		BIT6 // digitalPinToBitMask(TFT_RS) //
#define TFT_CS_MASK		BIT7 // digitalPinToBitMask(TFT_CS) //
empirejrz
Post by empirejrz » Wed Jun 28, 2017 1:50 am
I want to use touchscreen. I use library link below.
https://github.com/stevstrong/TouchScreen_STM32
My serial port print information.
Pin of the LCD Touch is
T_IRQ
T_DO
T_DIN
T_CS
T_CLK
Post by stevestrong » Wed Jun 28, 2017 8:45 am
It seems that your LCD controller is not an ILI9341, but SSD1289.
This controller type is not supported by my library, but can be added.
For initialization sequences please have a look at: https://github.com/prenticedavid/MCUFRIEND_kbv.
The touch controller is an SPI driven one, you have to detect what kind of chip is that.
Because my touch library is handling only 4-wire resistive signals and not specialized chips, please search the internet for an SPI touch library.
empirejrz
Post by empirejrz » Thu Jun 29, 2017 3:05 am
Thank you. I waiting new STM32F103RBT6 item because It has pins not enough. I want to use SPI for SD Card and Touchscreen.
Behind of my LCD
