Use STM32F103C8 with TFT 320QVT 9341
Re: Use STM32F103C8 with TFT 320QVT 9341
Post by stevestrong » Thu Jun 29, 2017 6:27 am
You have to detect what kind of chip is I2, the touch controller, and load a library for that.
david.prentice
Post by david.prentice » Thu Jun 29, 2017 12:22 pm
Your TFT display uses a 16-bit data bus + 5 control signals = 21 GPIO.
Your SD and XPT2046 use SPI i.e. 3 SPI + 2 CS + 1 IRQ = 6 GPIO
In other words, you are using every available GPIO on a BluePill or MapleMini.
My MCUFRIEND_kbv library supports the ILI9341 in both 8-bit and 16-bit mode.
I have privately posted a 16-bit SPECIAL for a BluePill. Of course, having made the effort to write it for them, they do not give you any feedback.
Quite honestly, you could use Mega or Due with commercial 40-pin Adapter Shields.
If your Display has a configurable 8-bit/16-bit solder-bridge, I suggest that you select 8-bit data bus.
It does not look as if there is a solder-bridge on your blue pcb. You would need to access the SMD R1/R2 on the the flexi-ribbon.
The display will work plenty fast enough. And you can choose sensible pins.
David.
empirejrz
Post by empirejrz » Tue Jul 11, 2017 2:45 am
if I used to STM32F303VC Discovery board. Can i use Adafruit_TFTLCD_8bit_STM32 libery ?
david.prentice
Post by david.prentice » Tue Jul 11, 2017 8:32 am
It looks as if the STM32F303VC Discovery has got lots of pins. But it also has lots of LEDs, Sensors, ... connected to these pins.
You will have to study the manual. Choose enough spare pins for your display. Then configure accordingly.
Not only is there a lot of wires to connect, but you will need to write a suitable write function for the 16-bit data bus. This is very easy if you can find an unused 16-bit PORT. It is a nightmare when you use random pins from different ports.
The only "plug and play" solutions are:
1. Mega + 40-pin Adapter Shield + 3.3V 40-pin Display.
2. Due + 40-pin Adapter Shield + 3.3V 40-pin Display.
3. Mega/Due + Mega Display Shield. i.e. you buy a new Display
4. Uno/Mega/Due/Zero/Nucleo/IteadMaple + Uno Display Shield. i.e. you buy a new Display
David.
empirejrz
Post by empirejrz » Tue Jul 11, 2017 8:42 am
Thank you very much to help me.
vincent47
Post by vincent47 » Sat Jul 22, 2017 10:43 am
hi can anyone help me interface tft 320qvt 9341 with stm32f401re using 8bit or 16bit parallel mode .. i dont know what library to use for the lcd and touch controller..thanks
david.prentice
Post by david.prentice » Sat Jul 22, 2017 12:06 pm
As far as I know, the TFT320QVT_9341 is only 16-bit. If you can configure for 8-bit life would be a lot easier.
There is nothing very complicated with driving an ILI9341. There will be several libraries.
The problem comes with "choosing" the wiring. I suggest that you just use whatever wiring the example has.
If you are determined to do it differently, try to put the data bus on a single PORT.
Control pins are easy to move.
Incidentally, the ST Core has a Nucleo-F303RE but not a Discovery F303VC. The Maple Core seems to have STM32F3 Discovery.
The thread is about using a 40-pin 16-bit 3.3V displays with a BluePill board.
I have just received a BluePill and 40pin header socket. So I soldered the board and header to some Protoboard. Plugged my home-made Adapter into a 16-bit SSD1963 display. MCUFRIEND_kbv works fine. Just like it works on a Due with Adapter Shield.
I have not tested the Touch and SD yet. There will be few GPIO pins left for anything else.
As I have mentioned before. If you test your wiring first, I do not mind writing a SPECIAL for you.
However this does involve you to do some testing and provide feedback.
David.
Post by zmemw16 » Sat Jul 22, 2017 12:12 pm
why am i seeing echos around here ? yesterday or day before it was software serial and hardware serial questions... ... ...
please just open a new topic in a relevant forum and not post to any threads mentioning something or other about your issue.
have you tried a search, maybe for 'qvt' gives this one http://www.stm32duino.com/viewtopic.php ... =qvt#p8114 & the first reply to that post points to some potentially useful code snippet(s)
david.prentice
Post by david.prentice » Sat Jul 22, 2017 2:22 pm
My apologies. I was replying to empirejrz with a Discovery-F303
I should have replied to vincent47 with a F401RE.
Both posters asked about the TFT 320QVT_9341
The same comment applies. Is there a Core for F401RE ?
If there is an "official" Core, I will post a SPECIAL.
If your questions do not apply to "Arduino" style code, say so.
This Forum is supposed to be about Arduino Libraries
David.
vincent47
Post by vincent47 » Sat Jul 22, 2017 3:12 pm
sorry if Im in the wrong thread, my board is stm32 nucleo-64 development board with stm32f401re mcu, I need to interface tft 320qvt_ili9341 but i dont know what library to use or how to port arduino libraries to make it work with my board, i want to learn how to this but i dont know where to begin, any hint or advice is very much appreciated.. :D
