Adafruit_ILI9341_STM - improvements
Re: Adafruit_ILI9341_STM - improvements
Post by RogerClark » Thu Aug 17, 2017 10:25 pm
As Steves latest code seems to work OK, I was planning to update the repo with his copy of this library and also his updated SPI lib.
But I have been too busy with other things to do it yet
Post by victor_pv » Thu Aug 17, 2017 10:46 pm
stevestrong wrote:
Thu Aug 17, 2017 5:14 pm
Guys, im on holliday currently, will be back in a week or so.
Steve, when you are back, if you haven't already you can remove this line, is a leftover from when the DMA transfers were done directly in the library, before adding dmaSend:
https://github.com/stevstrong/Arduino_S ... STM.cpp#L7
One more thing, wouldn't using dmaSendAsync here cause problems since the CS line may be toggled before the transfer is over?
https://github.com/stevstrong/Arduino_S ... M.cpp#L243
Since we can use DMA callbacks with the SPI, perhaps we could instead have a function toggle the CS pin when when called?
Manny
Post by Manny » Thu Aug 17, 2017 11:13 pm
l had compile errors with Steve's SPI lib and SDfat, other libraries might be affected.
Post by RogerClark » Thu Aug 17, 2017 11:30 pm
OK.
I only tested Steve's code with the ILI9341 lib. It needs to be tested with a wider range of libs e.g. SD
Post by stevestrong » Fri Aug 18, 2017 6:49 am
Victor, I corrected the things you mentioned.
However, because I am not at home, I cannot test it.
If you discover some bugs or have compile/build errors, please report it on github.
Post by stevestrong » Fri Sep 01, 2017 2:37 pm
Manny, can you please post here what kind of error messages do you get?
Manny
Post by Manny » Sun Sep 17, 2017 5:35 pm
Better late than never
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SdFat\SdSpiSTM32F1.cpp: In member function 'void SdSpi::send(const uint8_t*, size_t)':
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SdFat\SdSpiSTM32F1.cpp:91:20: error: call of overloaded 'write(const uint8_t*&, size_t&)' is ambiguous
   SPI.write (buf, n);
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SdFat\SdSpiSTM32F1.cpp:91:20: note: candidates are:
In file included from I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SdFat\SdSpi.h:124:0,
                 from I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SdFat\SdSpiSTM32F1.cpp:23:
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src/SPI.h:274:10: note: void SPIClass::write(uint16, uint32) <near match>
     void write(uint16 data, uint32 n);
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src/SPI.h:274:10: note:   no known conversion for argument 1 from 'const uint8_t* {aka const unsigned char*}' to 'uint16 {aka short unsigned int}'
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src/SPI.h:281:10: note: void SPIClass::write(void*, uint32) <near match>
     void write(void * buffer, uint32 length);
I:\Users\Manny\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src/SPI.h:281:10: note:   no known conversion for argument 1 from 'const uint8_t* {aka const unsigned char*}' to 'void*'
Post by stevestrong » Mon Sep 18, 2017 12:08 pm
Manny, I see that you are using non-DMA transfers. Is there any reason why you don't use DMA transfers?
Anyway,I posted two PRs to Greiman's repo to solve this issue. https://github.com/greiman/SdFat/pulls
Manny
Post by Manny » Mon Sep 18, 2017 7:27 pm
Good spot on the DMA...anyway, downloaded Greiman's repo and its all working with the Adafruit_ILI9341_STM and SPI libs from your repo.
